Neutron HiFi DAC V1 Review
Rate this portable DAC & HP Amp:
    Votes: 0 0.0%
    Votes: 11 5.6%
    Votes: 67 34.4%
    Votes: 117 60.0%
This question is more of a curiosity and maybe it is a limitation of the host devices' platform differences. Is there a way Neutron HiFi DAC could ever automatically toggle the "apple volume scale" setting without Neutron Configurator? I have to routinely switch when moving between my PC and iPhone. If there were a way for the DAC to tell by host device to change to the Apple volume scaling. Or if it could be changed without using the configuration app, that as well. Either would be a huge convenience and time saver for me.
Unfortunately USB device can't guess the host, host does not identify self.
@neutroncode Speaking of different hosts. Is it maybe possible to implement or activate UAC1.0 ability on the V1? As option in the advanced tab for example so one can choose if needed or even better if this will be recognised automatically on boot up.
The intended use case would be for PalyStation 5 or Nintendo Switch as those devices only support UAC1.0.
DAC V1 is based on a general-purpose NXP MCU and there is full control of firmware source code, thus basically everything is possible if it is within MCU's capabilities. There is already an option to enforce Full-Speed mode, it could imply UAC1.0 descriptor. If device is connected to a Full-Speed only host then DAC V1 falls back already to the Full-Speed mode thus even additional option is not needed unless you want DAC V1 in always Full-Speed mode.
Is it still widely used scenario, I mean PS or Ninendo + USB DAC?
Based on my observations, this option only sets the USB speed to Full-Speed, and its descriptor still shows it as UAC2.0. USB speed and UAC version should be independent.
One of my computers benefits from this option because it has no sound in USB high-speed mode.
(It seems everything on the computer is working normally: the player can play without error and NConfigurator works properly, just no sound. I compared the descriptors between the USB speed modes, and the only differences are in the USB speed and frame interval time information.)
I don't have a UAC1.0 device, so I'm not sure what will happen when the Neutron DAC is connected to them.
Noted - UAC1.0 shall be a separate option implying Full-Speed mode.
I benefit from Full-Speed more option too when using DAC V1 in a virtual machine on macOS or Linux. It does not work well with high-speed isochronous transfers but full-speed is ok. It is probably due to a timing issue when virtual machine is emulating the USB controller.
Depends on USB controller, OS and drivers for the motherboard. Maybe the problem is in the support of isochronous transfers in a high-speed mode.
On a similar note, I have a Nintendo Switch 2, which reportedly supports UAC 2.0. However, the V1 does not work with it. However, other DACs like the Chord Mojo 2 do work with the Nintendo Switch 2. I would be pleased as punch if I could use my V1 with my Switch 2!
Can be some software bug/weakness of NSW when it is parsing UAC 2.0 descriptors, found Reddit thread with reports on various DAC models working and not working with NSW2, PS:
Based on reports most probably the key is the USB descriptor and how it is composed, probably NSW2 respects some specific layout of USB descriptor. Will check USB descriptors of other devices devices and PM you if get something useful.
PS: @Hifihedgehog I PMed you with NConfigurator config to try first. Then will proceed with UAC1.0 works (+ option for PS4/5 + NSW/2).
I can't say how the demand for this is overall. I play PS5/Switch just occasionally but more or less regular. For me such an option is not crucial but would be a super feature if needed.
As the V1 has no buttons to switch the modes like for example the Fiio DACs in practise the max benefit for occasional PS/Switch users would be something like a "auto detection" if possible at all. If not possible an UAC toggle in NConfigurator setting as option would be still an addition imho.
Display say Hi! on boot up like normal. But the PS5 / Switch just don't recognise it as audio device.
Thanks! That didn't quite work but I am happy to continue cycling through a bunch of different firmware permutations via PM to see what works. I'm not sure how the Switch 2 works with some UAC 2.0 devices but it must be something simple if the Chord and Fosi devices have it figured out.
My Neutron HiFi DAC V1 arrived today and I’m impressed with it.
I have a couple of other USB DACs so I did a quick, and not particularly scientific comparison, of it and the FiiO KA15 and BTR 17.
With them all in ‘basic’ mode (no in DAC peq etc), connected to my Samsung Galaxy A16 and using Neutron player, they all sounded identical. No surprises there.
But I got this DAC because of its configurability, with the idea I could use it when streaming from Qobuz and get the same sound as I do with Neutron player, which I’ve configured for my headphones and preferred EQ settings.
It exceeded my expectations.
I played the same songs as FLAC files in the Neutron player, with no DSP in the DAC, and then streamed from Qobuz, with the DAC’s DSP set to the same as Neutron player.
Both setups sounded the same to me. Exactly what I was after.
Then I discovered the DAC’s ALC capability, which the Neutron player doesn’t have, and was able to tweak the sound further.
It took a little while to set up the Configurator app and create the presets I wanted, but the effort was worth it.
It won’t replace my BTR17, because Bluetooth is very convenient when I’m out and about, etc, but it will be my go to device for listening outside of my office/music room.
The DSP core is the same (not similar code but the same) as in Neutron Player, so basically DSP in DAC V1 is drop replacement for Neutron Player's DSP and from the point of energy saving it makes sense to use DSP on DAC V1 as it has better processing/consumed power ratio in comparison to main CPU which can be freed for other tasks (DSP overloading to hw).
Out of curiosity, I decided to try the Neutron DAC as a desktop DAC connected to my Windows PC by USB and active speakers (Argon Audio Forte A5) using a 3.5mm to RCA cable. I usually have a Topping DX3 pro+ in that role, which has much higher power output than the Neutron.
After increasing the speaker’s volume to a comfortable level I confirmed the Neutron sounded ok with all DSP switched off. No clicking or pops or distortion was audible (to me). Although I wasn’t doing any rigorous comparisons, it sounded much the same as any other DAC I’ve tried - in other words, no surprises here.
Now the fun began!
Using Neutron’s configuration app (in Windows) I created a profile that I set as follows:
Frequency Response Control: I set its EQ to the RoomFit settings from my WiiM Pro
Surround sound - on, default settings
Adaptive Loudness Compensation - bass boost preset
I left the PEQ off, though I could have tweaked the sound further.
Result: it put a smile on my face :-)
Obviously, this is 100% subjective, but it achieved a sound I enjoyed and meant I could play the Qobuz app (which doesn’t have DSP) without needing a player such as Audirvāna to get the sound I like.
I compared the specs of this with the Qudelix T71, which has had a lot of interest since Amir’s review.
Quality wise, there’s no significant differences, aside from the Neutron not having the ‘ESS hump’.
Power wise, the Qudelix has much more, but the Neutron has no issues with my ER2XR’s and was fine with my active speakers. And the Qudelix has balanced headphone out.
If I’m reading the Qudelix’s manual correctly, the Neutron’s DSP has more features, which certainly appeals to me as I love to experiment with settings.
My main use case with the Neutron is portable use connected to my Samsung Galaxy A16 and ER2XR iems. But I think it will see some desktop use as well…
DAC V1 development continues :D Many thanks to @AndyBell for noticing missed combination with Surround DSP. It makes sense to implement an easier DSP selection via check boxes, it is on radar.
Release Notes for Firmware 67:
Release Notes for NConfigurator 1.9.0:
NConfigurator Win32 installer and its EXEs and DLLs (except those shipped by MinGW) are now signed with a private key which you can install and OS will no longer show warning about "Unknown publisher". Certificate can be installed and uninstalled easily, here is FAQ: https://neutroncode.com/faq/86-faq-win32-package
The compatibility with Sony PlayStation 4/5 and Nintendo Switch 1/2 game consoles was added with Firmware 69 + NConfigurator 1.9.2 DAC V1.
Firmware now supports pure UAC1 mode (UAC1 descriptor + Full-Speed USB) that enabled compatibility with these consoles. There are new options in NConfigurator:
1) Advanced tab → USB Audio 1.0 (UAC1):
2) DAC tab → Fixed Volume:
Fixed Volume is required for PlayStation to overcome its volume limit. Basically this option fixes volume of DAC V1 at the level of the Volume Limit option.
Many thanks to @d1m0n for testing on PlayStation 5 and Nintendo Switch device! It was invaluable help.
@d1m0n found out that if Fixed Volume = Off and Apple volume scale option = On then PS will decrease DAC V1's volume to -8dB only, so it is also acceptable scenario. But with Fixed Volume it is possible to get 0dB from the side of DAC V1 on PS.
Firmware 70 and NConfigurator 1.9.3 were released today!
For DAC V1 the Firmware 70 is the most important update because it fixes nasty bugs happened due to its asynchronous core. It also improves ALC DSP behavior when Volume Limit is applied, now ALC is not affected by it.
I noticed there is content related to pop sound in the update log.
It reminds me of the pop sound when the audio stream stops, which mainly occurs in the right channel, precisely when the screen icon switches from playback to pause.
Depending on the playback software, the switching may happen several seconds to tens of seconds after the audio is stopped. Foobar2000 is the most suitable for reproducing the popping sound, as it immediately cuts off the audio stream when the stop button is pressed.
This has nothing to do with whatever the audio stream contains, even some web pages automatically start silent audio streams and then stop, which also generates pop sounds. I tried switching to high-performance mode, but it did not help.
@OHtaru besides DoP case I could not experience any pop & click in my case. In my latest experiments I was using sensitive IEMs, also kept DAC V1 connected via Isolator V1 (USB isolator) in order to exclude any noise induced via USB port. What you described is still valid with Firmware 70 in your case (the change in 70's is global to all modes - PCM, native DSD and DoP)?
Yes, this issue exists in Firmware 70. I have checked various combinations again, and this pop sound occurs in Full-Speed mode.
EDIT: This noise should not be an electrical issue, as I can still reproduce it using my phone.
