Firmware 60 + NConfigurator 1.8.6 are released.
Firmware's release notes:
NConfigurator's release notes:
There are important changes in this firmware update which improve noise performance of DAC V1's PEQ DSP. PEQ DSP was using float32, that is fully valid but due to 24-bit mantissa of the float32 type computations introduce quantization noise in the low frequency range. Now implementation is using fixed-point math that allowed to increase resolution and lower the noise.
Besides that, the output optimization via THD was revised towards more user friendly presets which cover all possible usage scenarios. For example, new preset [
No Load (DAC/Preamp, >= 1kohm)] achieves max DAC chip capabilities: THD = -117 dB, THD+N = -114 dB at 0 dBFS and shall be used if you are using DAC V1 as Preamp/Decoder between your USB host device and Amplifier.
By user request there is additional option in the Advanced tab [
Disable in-line Mic and Media Buttons] which turns off all Mic associated peripherals (ADC, Comparator, Amp chip) as well as Mic voltage bias, thus you get pure audio output only with headsets having inline Mic and buttons.
Screenshot with new options:
