- Joined
- Apr 21, 2024
- Messages
- 230
- Likes
- 529
engineers at Cirrus Logic about this issue?
It’s not the issue of CS chips, it’s the issue of „engineers” who cannot implement it well with all features. Maybe 130 pages PDF chip-dataSheet is too long for some of them.The result was similar to RAA test, CS DAC chips always show the distortion.
Exactly.It’s not the issue of CS chips, it’s the issue of „engineers” who cannot implement it well with all features. Maybe 130 pages PDF chip-dataSheet is too long for some of them.
RAA showed as well that some well done implementations do not have any issues, like Onix Alpha XI1 2XCS43198 + 2xSGM8262
I think that the most suited place is the dedicated CS threadEDIT. By the way, any further discussion on this topic should better be had in another, more appropriate thread. I am not going to make another post on this topic here.
www.audiosciencereview.com
Firmware 57 brings new sonic performance for DAC V1.
So to use this I need to select the 32 or 600ohm preset?
So if for example my IEMs and HP were all between 10-150 Ohm. I just set and safe 32, right?
For my sensitive IEMs I set the Output to 1V and reduced/limited the max vol via the slider accordingly as a precaution.
Is it then fine if I go till max here as I would assume I never reach the actual internal max volume you mentioning of the DAC?
About the THD compensation… I believe the results are also somewhat dependent on the load—the HP/IEM. Have you evaluated this?
- Minimum phase fast and slow filter in NConfigurator presets like you did with the linear types
- Larger display brightness range for the slider, so that the display can be set even darker than now when it is set to the smallest level.
Does the DAC support ASIO? Didn't see any information on the website. I want to use the DAC with DAW for music production.
What's the fastest way to change EQ preset on iOS?
Speculating a little...But Apple, I do not know the reason behind it, does not allow apps accessing USB device, at least HID access would do the trick in case of DAC V1 (it uses HID interface for NConfigurator needs). If they change this policy NConfigurator will appear on iOS immediately.
