Neumi BS5P Powered Bookshelf Speaker ($150/pair)
hardisj
Reviewer
North Alabama
Full review can be found on my website in case some of the formatting doesn't carry over well here.
https://www.erinsaudiocorner.com/loudspeakers/neumi_bs5p/
I noted the price in the title because I've gotten a lot of people asking about budget speakers so, here you go. ;)
Neumi BS5P Powered Bookshelf Speaker Review
  • Saturday, Apr 17, 2021
However, for those who want more - a detailed explanation of the objective performance, and my subjective evaluation (what I heard, what I liked, etc.) - please watch the below video where I go more in-depth.
Information and Photos
Note: Neumi sent me this speaker to test. I was not paid for this review nor has Neumi seen this review before publication.
The Neumi BS5P is a powered 2-way Studio Monitor featuring a 5-inch midwoofer and 1-inch dome tweeter. It comes with a variety of hookup options (Bluetooth, optical toslink, and RCA connections. It also comes with a remote control. The below is from the manufacturer’s website:
The BS5P is a powered bookshelf speaker designed for the budget-conscious music lover who wants a pair of simple, affordable, yet great sounding speakers. With classic styling cues, the BS5P is attractive yet unassuming, making it a great fit for the home, office, or garage. Play music wirelessly from your smartphone or computer to the BS5P using Bluetooth! Low-latency technology minimizes lip-sync issues when watching videos. Other inputs include optical and coaxial digital inputs for use with a TV, DVD/BD player, or game console. The analog input can be used with any analog source, including record players that have a built-in phono amp. With 75 watts of clean total power, the BS5P can fill a small to medium-sized room with high fidelity sound. Its capable DSP sound processing engine has been optimized for a smooth frequency response while limiting distortion at high sound levels. Convenient full-function remote for changing volume, switching between available inputs, and music playback control in Bluetooth mode. Based on the well-reviewed BS5 passive bookshelf speakers, the BS5P uses the same 5-inch fiberglass woofer and 1-inch silk dome tweeter. This design combination has been tuned to offer a good balance of bass output, midrange transparency, and treble smoothness. The result is music full of dynamic impact, accurate detail, and precise imaging.​
As stated in the above, this is a powered version of the Neumi BS5 passive bookshelf speaker set, which I also reviewed here.
MSRP is about $150 USD for a pair.
And here are some specs copied from the manual:
The front can be covered with a grille. The back features various inputs as well as buttons for power, source selection and volume/track selection. And a remote is also included.
A picture of the setup in my garage:
The reference plane in this test is just below the tweeter, per the manufacturer. A single RCA input was used and the volume was set to default. No grille was used and the ports were open (not stuffed).
CTA-2034 / SPINORAMA:
Early Reflections Breakout:
Estimated In-Room Response:
Additional Measurements
On-Axis Response Linearity
Response linearity is -12.44/+8.54 dB (80Hz to 16kHz).
“Globe” Plots
Vertical Polar (Globe) Plot:
Harmonic Distortion
Near-Field Response
Nearfield response of individual drive units:
Response Linearity (Compression and Enhancement)
The below graphic indicates just how much SPL is lost (compression) or gained (enhancement; usually due to distortion) when the speaker is played at higher output volumes referenced to 76dB at 1 meter.
Based on my results above, it is obvious the output is limited significantly somewhere above the 96dB @ 1m output level. I haven’t confirmed with Neumi if this is a built-in limiter, though, I assume it is.
Neumi BS5P vs BS5 (Powered vs Passive version)
Below is the on-axis response comparison of the BS5P and the previous passive BS5 I tested in June 2020. You can see the updated BS5P has a definite “V-curve” response to it, putting more emphasis on the midbass and high frequencies.
In-Room Measurements from the Listening Position
Below is the actual measured in-room response (with no DSP correction). This is a spatial average taken over approximately 1 cubic foot. The speakers were placed approximately 1.2m from the front wall (not the cabinets; but the actual wall). The listening position was primarily at 1.5m but for this test I measured the response at two different distances from the speakers.
Black = Predicted In-Room Response from SPIN data
Red = Actual In-Room Measured Response from Main Listening Position at 1.5 meters
Blue = Actual In-Room Measured Response from Main Listening Position at 3.5 meters
As expected, the predicted in-room response and the farfield response (3.5 meter, blue) line up quite well above approximately 500Hz. However, when moving to the nearfield (1.5 meter, red), the high frequency response is accentuated even more above 8kHz, reaching as much as +4dB compared to the farfield response/estimation.
Parting / Random Thoughts
  • Subjective listening varied between the nearfield at 1 meter and the farfield at 4 meters. Subjective listening was conducted at 80-95dB at these distances. Higher volumes were done simply to test the output capability in case one wants to try to sit further away.
  • The response linearity is all over the place thanks to the "V-curve" shape and the port resonances at ~800Hz and ~1.8kHz. These resonances were also present in the passive version so weren't necessarily unexpected. However, the V-curve response makes the response of this speaker much further from ideal.
  • Very punchy bass at all output levels.
  • There is a tendency for this speaker to resonate and hang on to notes in the 100-200Hz region a bit too long.
  • Very heightened high frequency content, which is fatiguing when listening long-term, especially at higher volumes.
  • Midrange vocals recessed.
  • Despite the manufacturer stating “optimized for a smooth frequency response while limiting distortion at high sound levels”, this is not a reference speaker. Furthermore, in my humble opinion, the BS5P is unfortunately a step-down in fidelity from the Neumi BS5 (passive speaker) I reviewed in the past.
  • These speakers have very good directivity, outside of the port resonances and therefore should respond well to EQ. In which case, they would make a good option for computer speakers if you can implement EQ to tame the exaggerated bass and highs.
  • If you are, however, looking for a speaker with a lot of pizzaz and a lot of hookup options then this is an option for you. That said, I would not necessarily recommend these for TV as the dialogue frequencies are recesses relative to the high and low frequencies.
As stated in the Foreword, this written review is purposely a cliff’s notes version. For more details about the performance (objectively and subjectively) please watch the YouTube video.
Support / Contribute
If you like what you see here and want to help me keep it going, please consider donating via PayPal through this link. Donations help me pay for new items to test, hardware, miscellaneous items and costs of the site’s server space and bandwidth. All of which I otherwise pay out of pocket. So, if you can help chip in a few bucks, know that it is very much appreciated.
hardisj
hardisj
Reviewer
North Alabama
If you watch the video you'll find out I'm bummed by this design. They took a really great budget speaker ($90/pair for the passive version) and managed to screw it up when all they had to do was put a plate amp on it with some I/Os and call it a day.
hardisj
hardisj
Reviewer
North Alabama
I wonder if some of it is just part variation for these cheap drivers. Like with Vanatoo I think the company even said so when Amir’s measurements came out.
Possibly. Though, @joentell told me he heard a distinct V-curve to the response and when I sent him my PIR curve, it overlaid on his in-room measured response. This indicates two different sets of speakers behaving the same way.
beaRA
This is disappointing. I was hoping for a soundbar alternative better than the Edifiers that I could recommend to people on a tight budget. I've been suggesting the passive BS5's recently as there aren't many other good options in the ultra budget category right now.
richard12511
Seriously! They took a pretty great budget bookshelf speaker and gave it one of the worst batman curves we've seen :(.
What's going on at 850Hz and 1.7kHz?
Ericglo
Sorry Erin, I admit that is a pet peeve of mine to read first before asking a question and I went and did it.
Admittedly, when I see a poor performing speaker like this I just scan the review and usually dismiss the speaker. Ironically the bad reviews sometimes get the most discussion.
Since Neumi sent you the speaker, I wonder if they knew the port resonances would be this bad. Maybe they should take a look at Augerpro's recent tests and redesign their ports.
https://www.somasonus.net/box-construction-methods
hardisj
hardisj
Reviewer
North Alabama
They absolutely did. I had email exchanges with them about the port performance when I reviewed their passive speaker (BS5). That's why I'm so bummed about the overall performance of this speaker. At the least, they could have just added an amp with the BT/Coax/Optical/RCA inputs and called it a day. But they instead tweaked the output to perform even worse than the original (which, IMHO, is still the best budget passive bookshelf speaker out; port resonance and all).
Ericglo
I wonder if they would have been better off going with a sealed box.
Also, are the ports straight tubes or flared?
hardisj
hardisj
Reviewer
North Alabama
Based on my recent discussion with Earl Geddes (discussion about it here), I decided to implement an additional compression test as I think this is another bit of data that can really help us understand how we may subjectively prefer one speaker over another. This differs from what I was already offering in that it is long-term. I have subsequently re-named my previous testing "Dynamic Range (Instantaneous Compression Test)" because I feel it is the most useful way of relaying speaker dynamics in test data. So, now I have two types of compression testing:
1) Short term (already had)
2) Long term (new test method)
I have updated my review with this new set of data but have also retroactively updated the text around #1 above. Here is a direct copy/paste of those two data sets.
  2. 86dB at 1 meter (red)
  3. 96dB at 1 meter (blue)
  4. 102dB at 1 meter (purple)
Long Term Compression Tests
hardisj
hardisj
Reviewer
North Alabama
Some good news.
After I published my review, Neumi reached out. They were really perplexed as to how the results could be so far off from what they intended to build. They went to the drawing board and released a couple FW update options: 1) no EQ and 2) updated EQ.
I downloaded both and listened back and forth. I then tested both settings. The updated EQ is much better but not without issues, all apparently caused by the ports which was the same story I had when I tested the passive versions. So, I stuffed the ports and listened again. Muuuuch better. I threw it back on the Klippel NFS (making this the 4th test I performed on the speaker). The result?... much, much better.
I'll drop a "revisited" review hopefully within a week but the bottom line is that I now have no issue recommending the BS5P with the updated EQ and stuffed ports. And if someone prefers the ports opened then it is still an acceptable response and nowhere near as v-curved as before.
This is a fine example of when a company is receptive of feedback and is willing to make changes to improve their product.
