NeumannContol iPad® App missing from appstore
tyanlion
I can't seem to find the Neumann Control app on the appstore. Is anyone else having the same problem?
I thought they stopped maintaining that a few years back in favour of the MA1 Windows app. If that's right it won't have kept up with the changes in app store requirements, and has probably run out of grace period.
How do I change the wake from auto standby for my KH80s on the MA1 app volume level? There doesn't seem to be any option to change the volume level, just the ability to turn on and off standby. On the old iPad app there use to be a setting that you could change that affected it.
Is there anyone who can operate with the Neumann Control App? I also can not find the app. I hope to run it on MacOs or iOs in iPad. Is this still possible?
I don't think Neumann ever supported MacOS. If you can cope with a command line interface you could give khtool a try.
