DJBonoBobo
A few more infos if someone wants to know:
- iPad only, no iPhone
- crossover frequency can´t be changed yet (they promised to include this feature in future updates)
- there is a demo mode available: if you have an iPad and if you are considering buying the KH 750 (or KH 80), you can use the app and try out every setting, even if you don´t have the loudspeaker yet
- settings are stored in the device, so if you don´t have an ipad, you would be able to borrow one, make all adjustements and give the ipad back. If you want to use the loudspeaker in a different location afterwards and no ipad is available you can disable the stored network settings temporaryly and use the backplate-switches instead.
I like the app, but i´m experiencing some hickups, though. Sometimes the app disconnects from the speakers or doesn´t respond for some time. Because of that, i personally would not use the app as an everyday (remote) monitor controller, even it would be possible to do so, because it´s easy to control volume and so on for the whole system.
