DJBonoBobo
Hello,
i have a dual sub Neumann system (2x KH310, 2x KH750 DSP). I use the MA1 microphone and software for room EQ. I also own a Dirac Live license (PC standalone) that i have not used for a long time. Because Dirac released DLBC, i decided to get the trial version and compare the results of DLBC and MA1.
Dirac offers a discount for DLBC until March 22nd, so maybe this is of interest for some. Unfortunately i had no time making listening tests and my trial license is already expired today.
Disclaimer: I am a home user with no special technical expertise in doing this comparison. I am only sharing what I noticed in my room and make no claim that the results can be applied to others.
Room:
This is how the setup looks like at the moment, listening distance is about 1.80 meters. Best positions for the subs are the corners. The room is about 3.0x5.0x2.5 meters. As you can see i have some treatment (mostly basotect, also 2 DE-MITTER from greenacoustics and 2x PSI AVAA at the back of the room. There is also a bed and a big closet filled with clothes) in the back of the room.
Abbrevations:
MA1: Measurements with MA1-correction active.
DLBC: Measurements with DLBC correction active.
no prefix: Measurements of speakers without DSP.
L: Left KH310
R: Right KH310
LSub: Left KH750
RSub: Right KH750
2Subs: Both KH750 together
Mic, crossover, volume and drivers:
In both cases i used the same mic with calibration file and the same positions (as far as possible). The crossover frequency was 80Hz in both cases. Due to the different hard- and software requirements i made the measurements not at the same level (Dirac calibration was quieter) and tried to align them afterwards for comparison. Particularly for the subwoofers i don´t really know how to do that correctly, so i can not interpret the subwoofer graphs 100% correctly. For Dirac i made Java-measurements with RWE, for MA1 i used ASIO. I don´t know i some of the differences may be influenced by this. I always used the same channel (left main) for acoustical timing reference.
Target:.
MA1: I used the automatic target curve with no customization.
DLBC: I reduced the bass from +6db to +3.5dB. As you can see it is still more bassy than the MA1 target. The default target has way too much bass for me.
In my comparison i focused on the most problematic crossover area from 70-120Hz.
Frequence response graphs:
Without correction:
With DLBC:
With MA1:
Left channel comparison:
Right channel comparison:
RMS Average comparison:
Left subwoofer comparison:
Right subwoofer comparison:
Both subwoofers (you can see different approaches of the programs - DLBC seems trying to fit both subs tightly, much more variance between MA1-subs):
Phase response graphs:
Group delay:
Step response (disclaimer: i don´t know what that means/how to interpret this - i just noticed the big difference and wondered if it´s important somehow)
Additional DLBC stuff (could not do this with the MA1)
Left KH310 only
Right KH310 only
Preliminary conclusion, what I think I understand:
- MA1 leaves >3khz alone in my case, DLBC fiddles a bit with this.
- MA1 boosts the sub around 85Hz, DLBC boosts the mains around 120Hz
- Below 30Hz is much louder with DLBC. I don´t know why MA1 is so shy there.
- DLBC looks a bit better overall because of the 120Hz-area.
- MA1 has a much better automatic target (for me in my nearfield-situation at least).
- In terms of phase and group delay the MA1 looks better, i think? Not sure though.
- The results are pretty close, but some different "choices" lead to a few differences.
- I have not yet compared latency - i don´t know how to do this.
- If you already have a Neumann system, I think the MA1 has much better value (around 250 EUR for mic+software) than DLBC (729 EUR without mic for stereo), but DLBC works with other subs and has a multichannel-option.
What do you think – is there a winner?
Room:
Abbrevations:
L: Left KH310
R: Right KH310
LSub: Left KH750
RSub: Right KH750
Target:.
Without correction:
With DLBC:
With MA1:
Group delay:
Left KH310 only
Right KH310 only
