Hi guys,
Long term lurker and first time poster here so hello from an ASR newb!!
My current 2 channel domestic setup consists of 2 x KH80's and 1 x KH750 with my source an etherneted RPI 4/Allo Digione Hat running Volumio going BNC out directly into the KH750 for it to do its DSP magic in conjunction with the KH80's.
My question is, given that the digital out of the Allo is fixed volume and the only way to attenuate the output going to the KH750 is via the software control in Volumio, (I'm under the assumption that reducing software volume upstream is potentially detrimental to bit-perfect playback) Feel free to tell my assumptions are wrong but if not, is there a more transparent, less compromised and higher quality solution to control the volume using a hardware volume controller/signal attenuator prior to the signal hitting the KH750?
I could theoretically insert something like a Mackie Big Knob between the analogue outs of the KH750 and the analogue ins of the KH80's but that would only control the volume of the KH80's and not the KH750s which defeats the purpose.
One solution is to insert a DAC/digital preamp (RME ADI for instance) between the BNC out of the Digione ad go into the analogue ins of the KH750 but I don't need the DAC part as I'm using the ones built into the speakers and am definitely not keen on increasing the number of digital > analogue conversions taking place.
I hope all this makes sense!!
Thank for reading.
Phil
Thank for reading.
Phil
