Multicore
- Joined
- Dec 6, 2021
- Messages
- 5,128
- Likes
- 6,905
Good and bad. The good is that's an intelligent engineering-grounded response that shows they paid attention to your problem and considered the Yamaha comparison. The bad is that they are saying you should buy their matching subwoofer (they aren't the first to say this). Then you won't be sending sub bass to these boxes that can't convert it to air waves.Info from Neumann, I am not shure if they checked provided audio or not.
Is there a chance someone with KH 120 II will check on their pair.
Audio files:
kh 120 test - Google Drive
drive.google.com
You might enjoy this thread. I did. The lesson for me was, that's what it takes to make full-range monitors that can do the spec SPL. That's the best we can do. It's easier and less expensive to solve the problem with band-limited L+R and sub woofer(s).
Why are main monitors so powerful?
When I browse the catalogs of the vendors of speakers for studio installation, I marvel at the colossal SPL output of the big main monitors. But I remain unclear what exactly the 130 dB SPL is used for. I've no doubt it is important in some situations but it's hard for me to imagine. Is it for...
www.audiosciencereview.com
