computer-audiophile
LOLThe old cabinet wsa more "ringy" as the new one.
I did a direct comparison and put the soundfiles here in the thread. Search it up.
No, I had used the KH120A for 10 years nearly every day and I didn't notice anything like that. I thought the cast aluminium housing was of particularly high quality and see the new one as a cost-saving measure, even if it is perhaps no worse. I generally don't listen to sound files on the Internet that are supposed to prove some kind of tonal subtlety. I think it's an unsuitable means.Do YOU have both speakers next to each other and tested it?
That is true. Also many turntable platters are ringing when you hold them in your hands and bang upon it. But it is without relevance in normal operation, when it ist damped by the mat e.g. or other means.... the aluminium has a little ringing when nocking,
Yeah, no, but the front is plastic, i think.I didn't know MDF is a kind of plastic.
Ok, I can easily agree with that. I, on the other hand, don't like acryl as a turntable platter material at all. I have been involved in turntable tuning for decades and have also used a stethoscope, for example, to track down vibration nodes. The vibrations of the cabinet were also an issue when building my own loudspeakers.That's the reason I got an acrylic turntable platter ;-) Acryl is a great material cause it's heavy and provides some damping.
I also don't think the alu housing makes problems with the KH120 or Genelecs but it's nonsense to say aluminium is the better material for building speakers - it CAN be good with some caution and additional damping.
In your case you might not need or even might not be able to make use of the MA1 system. Because with your Non-Neumann subs your AVR will have to handle all the room correction, the sub / mains cross over and the phase alignment of the sub and mains.Happy holidays. So - Talk me into a KH-120-II L-C-R upgrade!
If I decide to do the KH-120-II + MA-1 deal (from https://www.musicstore.com/en_US/USD/Neumann-KH-120-II-Black-Promo-Set/art-REC100 - damn good deal!) - How do I go about adding a 3rd KH-120-II for Center? Do I need to buy another MA-1 license, or will the MA-1 included in the pair also cover the center? I'm also poking Sweetwater to see if they will come close to the musicstore.com pricing (they have worked with me on pricing in the past as I have a sizeable purchase history through them).
Size wise - the KH-120's are a noticeable step-down from my larger 8" Dynaudio AIR-15's (Active/DSP'd and Bi-Amped with 200w+200w - circa 2002). Even my current surrounds have a larger footprint (Dynaudio BM-6P 6.5" ported passives). MLP is approx. 9 feet (3 meters).
Since I have subs, I'm thinking the actual output will be comparable (if not on-par) between them, while also getting a nice improvement in overall presentation with the KH-120's. I've had to repair the PSU/DSP/Amp modules on the AIR-15's numerous times now - and at $375 per repair - I'm at the end of my rope trying to keep them functional. I was pondering going full external bi-amp on them with BuckEye and MiniDSP - but that seems to be pissing money away.
I'm familiar with the original KH-120A's as we run them in our QC stations at work, and only had 1 or 2 fail out many dozen units. I'd really like to see a KH-150-II, but I know the price and availability will both be deal-breakers for a new L-C-R setup. TBH - The smaller size of the 120's will also help with some space limitations I'm running into trying to swap my current/aging 60" TV for a new 65" TV (60"s seem to have gone the way of the do-do). Maybe upgrade to L/R KH-150-II's later - and move 120's to Surrounds.
Remainder of the system is an older Denon AVR-4000X (MultiEQ XT32) with various sources, Dynaudio BM-6P passive surrounds, JBL Loft 5" wide-heights (not Atmos); MiniDSP 2x4 Balanced for Sub management, and two Dynaudio AIR-BASE-2's (dual 10" each) on external amplification = Crest CA9 (overkill). The subs are happy running pretty high as needed to meet the 5.25" in the KH-120's (100Hz is not out of the question). Mostly used for TV (L-C-R), but this is my primary 2.2 music enjoyment system as well.
Thanks for either talking me off the ledge, or giving me the confidence to jump in with both feet! I have an itch to upgrade, but the continual repairs for the 20 year old AIR-15 system and potential improvements from a smaller system are really piquing my interest. The price from musicstore.com seems like a no-brainer.
Toodles![]()
Yes a new AVR might be a better bang for the buck.Thanks for the fast reply!
Interesting. I'll need to ponder then.
I'm using individual PEQ in my current AIR-15's and the MiniDSP 2x4 (for Subs) to get the major issues sorted with UMIK-1/REW, then I run Audyssey (only to switch to "GEQ mode" and lessen most of the corrections lol). My AVR is not "iPhone App" compatible for Audyeesy. A new AVR with iPhone-app compatible Audyssey is also on my list - but likely after the L-C-R upgrade. I could see that totally eliminating the need for MA-1.
Is there any way to have the MA-1 correct the L-C-R system as "full-range" (possibly even with the "C" as a separate Left channel; corrected as a standalone system) - then let me chop it up (bass management) between the AVR and MiniDSP? The speakers would not be networked, but likely run standalone - or as 2 separate systems (L/R pair, and C as an orphaned L of a second pair). Or would that also require a second MA-1 license for the orphaned Center?
Alternatively - Is the 120-II's onboard PEQ manually accessible w/o purchasing MA-1 if doing my own UMIK-1/REW measurements? This would also be acceptable. My current speakers only have 5-bands of PEQ - so that is really all I need (plus MiniDSP for subs).
Neumann KH 750 DSPI want to buy them, what's best sub with them for untreated room?
As @IamJF wrote. KH750. In order to take advantage of MA1 and integrate a sub correctly with KH DSP speakers eg 120ii via MA1 you need the KH750 as it also has a built in DSP to which the MA1 can “talk” to.I want to buy them, what's best sub with them for untreated room?
