Neumann KH120 II Monitor Review
Rate this monitor speaker:
    Votes: 5 0.9%
    Votes: 6 1.1%
    Votes: 47 8.5%
    Votes: 498 89.6%
Bonjour TA21,
J'ai ces enceintes avec des supports Iso Acoustics 155 depuis 18 mois maintenant et elles fonctionnent très bien (voici quelques photos pour que vous puissiez voir à quoi elles ressemblent).
Thanks for sharing the pictures.
The ISO-200 is usually recommended for these, I'll probably get those eventually. Just sitting on some cheap foam pads for now.
Purifi 6 inch or other for comparison to kh120ii? I thought you were discussing the kh150 woofer 6.5 inch to the purifi 6 inch. The smaller purifi 4 inch drivers are relatively new, and significantly smaller.
I too am considering these instead of passive purifis. But am worried about faults developing and the on going courier cost to send it back for repair (should I need it). I am in uk, but would need to send them into Europe to get repaired.
Safer in terms of developing faults is using a suitable purifi 2 way passive with a hypex amp. Using my Wiim ultra for dsp.
But having it all in one package is more convenient with much more settings and customisation options for a decent price saving with warranty of course.
I had probably more Hypex amps dying as Neumann Speakers ... and both is too lilttle to worry about. Everything can and will break, don't let your fear dictate to unrational decisions. Buy a 3rd 120KHii when you need 24/7 availability for the next 10 years - price is still competitive and you would need to do so with every other speaker too.
Wiim ultra is very basic as DSP and conversion is not up to the rest of this chain btw. I also use one to feed my KH120ii in my office and use the digital output. MA1 is WAY better for calibrating the speakers to your room and liking.
KH120ii woofer is in the quality range of Purifi - not identical to XY Purifi driver. For such a cheap driver it's an amazing result.
Btw - what Purifi passive 2-way kit do you have in mind? It's not an easy task to get on and off axis as perfekt as these Neumanns - but not impossible.
The only one which comes to my mind is the original from Purify: https://purifi-audio.com/shop/spk16...=9114,9121,9127,9122,9123,9124,9125,9126,9128
That's € 2000,- + tax. Add the Hypex amp and good DAC ... and some wood and PLENTY hours of work ... and you get a GREAT speaker.
But you could buy 2x KH120ii + KH750 + MA1 for the same money. Now add €10,- for every hour you are working on the project ... and get a pair of KH350 ...
Unfortunately, after just four months, my left KH120II has started producing a crackling noise from the tweeter. It happens randomly and is most noticeable when there's no audio signal (it can even be heard with all cables disconnected except the power cable).
Just to clarify, this is not the usual background hiss you would expect from an active speaker. Could this possibly be related to the power supply section?
I'll keep monitoring the situation and may end up sending the speaker in for warranty service.
This is so sad because it's an excellent monitor but reading this make me hesitant to consider it
I wish Neumann could comment about it here (if there on ASR)
There are many probable causes - could also be a damaged (not by you) transistor or diode somewhere in the signal path.
Apply for warranty immediately. It won't get better, and if it does it may reappear later when out of warranty.
Hi--I've been going back and forth with Neumann for about two years regarding this, over several 120ii's and 150's. Eventually they were kind enough to escalate to the team in Germany, earlier this year. Here is the most recent response from Oct 12:
Appreciate your ongoing patience on this.
The monitors have been investigated, and the good news that cause has been identified by our Quality team. Your monitors will be assigned to service to address.
The problem is related to a production issue which is now being addressed.
The investigation remains open however, as we are now identifying the impact (how many units are impacted - unfortunately, as yours came from our distribution channel, its likely quite a few.)
You are obviously entitled to two working monitors ASAP, and yours will be addressed by our service in Germany. I wanted to keep you in the loop, and will work on getting you two properly functioning units ASAP. I'll of course keep you posted here.
I really thank you for your cooperation and bearing with us here.
Seems like something is/was going on in the manufacturing process. I'll update with any developments. In the meantime, if you open a ticket and reference mine (328024), maybe they can get a better idea of how widespread the issue has been.
I also want to add that Neumann/Sennheiser customer service has been really kind and helpful. It seems the customer-facing side of the company was blindsided by this issue as well.
The biggest reasons I can guess for some people not experiencing this issue is that
1) they have the speakers far enough away that the static 'disappears'
2) their ambient room noise is masking it
3) a combination of those two
4) they lucked out and got defect-free units.
the actual timbre of the crackling is very similar to a well-functioning 120ii/150: a kind of soft static noise. But on a well behaved unit, it is constant and quiet. On a defective unit, it seems to go up and down in volume and 'graininess'.
I'm closing in on 10+ months with my L-C-R set of KH-150's and so far no issues - so hoping I'm in your #4 above - but could honestly be #2 with my hearing lol.
Interesting to see the teardown @LambdaCDM posted - the mainboard is shared between KH-120II and KH-150 - so if you have issues with both speakers - the issue would seem to be in that common area (ADC/DSP and such?) and not the amp sections and PSU which likely differ... (corrected below - Neumann rates KH-120II and KH-150 with identical power specs - I stand corrected!)
Might have missed this - but does the issue happen with both analog and digital ins (input selection)?
It's input agnostic; happens even with no audio cable, and regardless of local or network setting. In my troubleshooting, I was able to rule out EMI, power source or phone interference.
Based off the response I got from Neumann, it seems the issue can't be mitigated by the end user, and is specific to the speaker manufacturing process.
No matter the position of the input selector? (understood even with no signal cables connected)...
If so - that rules out the common ADC/Digital input section, and points to DSP IMO. We know the amps and PSU differ from the two models that share the common mainboard.. Well it appears they might be the same amp sections according to Neumann? I swear the 150 had quite a bit more power? My mistake...
Rates them both as:
Output power woofer amplifier (THD+N with limiter deactivated: 10%)145 W
Output power tweeter amplifier (THD+N with limiter deactivated: 10%)100 W
Output power woofer amplifier (THD+N with limiter deactivated: 0.1%)120 W
Output power tweeter amplifier (THD+N with limiter deactivated: 0.1%)80 W
Mains Power Supply: input voltage; frequency100-240 V; 50/60 Hz
Power consumption (230 V / 100 V): Standby0.3 W
Power consumption (230 V / 100 V): Idle15 W
Power consumption (230 V / 100 V): Full output320 W
yep. I was initially thinking DSP as well--sometimes I feel like I 'trigger' the crackling, especially with bass-heavy audio. But then sometimes it just happens on its own. Might be the DSP limiter or something.
Maybe I'm misinterpreting the service rep's words, but in our emails they seemed pretty sure that it wasn't going to be solved by a firmware update. An issue with how consistent the internal shielding is manufactured, for example.
I asked for the specific cause but haven't gotten a response...wouldn't be surprised if it's a 'all-hands-on-deck" situation over at Neumann right now.
Rates them both as:
to reply to your edit--the power draw is the same, I think overwhelmingly the internal spec is the same too? Never really delved into the electronics. But I know that the 150 is the 'default' size for the topology, and the 120ii is Neumann's attempt to squeeze it into a smaller footprint. Bass extension is similar on paper, but in practice the 150 sounds significantly deeper and more 'realized'.
Keeping my eye on this for your updates!
How is it possible to know when the manufacturing is fixed?
I guess the rep I've been speaking to will let me know. At least for my speakers, I am getting a 'fixed' version direct from Neumann, whenever that is.
It is unlikely Neumann wants to put a date on the fix, especially since they're probably still discovering the scope of the issue; even after fixing the manufacture, they'd still be figuring out the logistics of helping every single customer and retailer affected.
Many KH owners are here on ASR - I'm sure we would hear from quite a few more if it is actually a widespread/chronic manufacturing issue (and most have more sensitive ears than mine regarding hiss/noise floor and would surely report/complain here). My 150's are doing just fine after 10 months (they go to standby, but never get powered off in those 10 months except for a few minutes total).
As helpful as ASR has been for me, I think there's a sample bias here that can contribute to a lack of speaking up--it seems many people here are recreational listeners, and less are doing audio work in controlled environments. For recreational listening in a more reflective/colored space, this 'crackling' might go unnoticed. Just a guess, and obviously no judgement on anyone who buys any kind of speaker for any kind of purpose.
In general, I've found that doing any kind of mass-spread issue troubleshooting on internet forums runs into this same issue...people of different hobbies and needs congregate together in separate places, so it's hard to get a full picture.
I had the same problem and i bought them from thomann. Ive posted mp3s and a video showing the crackling noise from tweeter. I hope they will tell us the problematic serials so we can send them back.
What happens when our warranty expires?
Get your support ticket in now, so you've established having the issue under warranty. If you've already done that, then we're in the same boat...just waiting.
Also, for what it's worth, I sent them L, R and stereo files recorded at 48k/24bit, using schoeps cmc6 mk4's, running into a Camden ec2 preamp. I didn't normalize the files, but boosted them maybe 12 db or so. All to say, I gave them pretty definitive proof...sometimes an mp3 or similar lossy file gets rejected for this purpose.
