Long story short; two out of three speakers I've ordered had a vibrating zzz-noise when playing a sine wave of 450-550 Hz at medium-high volume. The exact frequency seems to vary a bit between tests.
The vibrating zzz-noise, or possibly coil whine, or something like that, comes from the speaker's back side. In some cases I was able to reduce the noise by holding a finger on the XLR contact, thus absorbing the vibration. (I've tried switching XLR cable which did not make a difference.)
So I started by ordering two speakers where one had this problem, the other one did not. So I returned the speaker with the problem and got a new one which also had this problem.
So I'm just checking with the rest of you if this is something you have heard of or encountered? Because either:
1) There is a systematic failure in design or production of the Neumann KH 80 DSP, in which case we should have heard of more of this, but I have not found any other reports of this so far.
2) I've been extremely unlucky, in which case I could just order a fourth speaker and it should work okay
3) The speakers are fine and something else is wrong with my setup. But I've tried my best to rule this out: First, I've tried different speaker locations, and that can cause the resonance frequency to change a bit, but still I can hear that the sound in fact comes from the speaker's back side. Second, one of the speakers does not have this problem.
Let me know what you think. Thanks in advance!
