- Thread Starter
- #161
I guess you don't consider the JBL M2 monitors that came as a result of the same research? Or the LSR series of monitors?That is true for consumer class loudspeakers like usually Harman compares (tests like Revel vs. Magnepan or B&W ) but when the level gets higher like with top of the line studio monitors and/or your use EQ to correct little imperfections then hearable problems like IMD play a bigger roller than expected.
That aside, heaven help you if you are correcting "little imperfections" you see on frequency response graphs with a single microphone measurements. Heavy handed correction that way is a sure way to get bad sound, but pretty graphs. I don't listen with my eyes but if you do, then that may be good for you, but not me.
Having had the JBL M2s and played them with 2000 watt+ amplification power, they would scare you out of the room way before any audible distortion sets in. I will be measuring distortion after I research it more but be very careful in throwing those words around like IMD.
Recently Sean Olive and crew tried very hard to see if they could establish preference based on distortion in headphones but could not. Between two different transducers, the difference in frequency response is so large that it dwarfs other factors. Now, if you are designing a speaker and have a choice of low or high distortion drivers, then by all means choose lower distortion. That is a very different thing than selecting between two speakers with different frequency response.
