Neumann KH 150 Monitor Review
Rate this studio monitor
    Votes: 0 0.0%
    Votes: 3 0.6%
    Votes: 44 8.5%
    Votes: 470 90.9%
CMB
KH310 and 8050 do not have room correction DSP so its an apple with pears comparison. Its direct competitor is 8340 which is older and does not have the same measured performance and its list price is similar to the KH150 one, it is offered cheaper though because it is older.
You pay extra for dsp right? Or is it included?
I saw something like Eur 250?
Andreas007
Germany, Bavaria
In my opinion the KH150 is somehow oddly placed - despite being a great speaker.
Especially, if you're thinking about an upgrade from KH120 or any other speaker in that range.
The additional low end is simply not enough to justify it.
I can imagine that after some time you will end up wishing for more bass extension or a subwoofer, again.
For 1000 Euro more you will get the KH310 which is not so harshly cut-off at the low end (at 30 Hz there's 20 dB difference between KH310 and KH150).
Therefore, in the long run I guess it is a more satisfying speaker which sounds more "complete" on it's own without urgent need for a subwoofer.
Reading amirs' comments on KH150 and K310 bass response is also clear indication that KH150 is not an option if you want somehow "full range":
KH150:
This persisted across many tracks which I contribute to nice bass extension. That led me into thinking subbass response would be good as well. That was not the case. Much of it is filtered due to sharp drop off in response. So for that, you still need a sub or a much larger monitor.
KH310:
Wow, wow, wow! This is some impressive bass coming out of this speaker! It was resonating not only my desk and chair but my entire loft! I cranked it way up and then I could detect a bit of distortion but if you were not looking for it, you would be plenty satisfied.
abdo123
Brussels, Belgium
That is diffraction above XO range.
Does it really matter what it is ?
I always viewed the DI trend line more like two or more slopes (1 per driver) rather than a continuous line. More like this:
The woofer purple and the tweeter yellow. That peak being a simple artifact of wher they meet, because of their differing angles. Am I wrong about that?
Erin shares horizontal only directivity indexes and I learned from there that the blip is 99.9% of the time caused by the vertical positioning of the drivers, so i always consider the blip the outlier.
dshreter
To get the objective result on par with kh150 you need custom designed drivers and a klippel measurement system .
Add to this the know-how of Neumanns engineers and you are read to go.:)
and the ability to design and manufacture a wave guide + deeply customize a DSP amp
kimmosto
The Directiva R1 has a blatant directivity mismatch (that has been discussed to death on the directiva threads). the KH150 is arguably more text book perfect.
One small comment about this. Amir should stop using his artistic talents for drawing multiple lines over measurements. Possible S shape compared to smooth line/arc also in that case can or should be visualized with a single line or arc. Not with two separate lines which are drawn to create or emphasis some assumed problem visually.
abdo123
Brussels, Belgium
I drew these lines.
Trell
The KH310 is also a much larger speaker than the KH150.
kimmosto
I think yes. Otherwise members are just guessing and blaming some design detail without actual knowledge that better applications are possible and exist in real life. Just praising brand or false interpretation of measurements or reviewer's short subjective comments about on-axis listening using single speaker.
MCH
KH150:
KH310:
Actually, one of the advantages i see on these is the possibility to add a sub properly integrated without spending significant $$ in additional boxes and software
Andreas007
Germany, Bavaria
True, but I would not say "much":
thewas
Higher directivity is not required or at least not the best solution imo when listening distance increases. Of course massive directivity and radiating area could move sound images closer and make them bigger, but acoustic resolution is maintained to very long distance with adequate room acoustics (=without flutter echo). So that is the best approach if possible.
Yes, room acoustics matter there a lot but I think this also a matter of personal preference, there is a significant percentage of listeners who like to immerse into the (suitable for that) recordings like in nearfield listening and for such a high direct sound percentage is necessary.
thewas
Also of the increased vertical directivity at the crossover point since it is not a coincidental design. And yes, as with many loudspeakers with large directivity tweeters it has some constant directivity characteristics which cause that change of slope.
Pearljam5000
You pay extra like GLM
And to me it's just not worth the price as you can get bigger speakers for the same money
Reactions: CMB
thewas
The DSP hardware is included in the loudspeaker, the measuring microphone and software costs extra, same like the GLM package of Genelec.
abdo123
Brussels, Belgium
Well you seem knowledgeable enough not to blame the inevitable outcome of the mismatch in vertical positioning between drivers in a 2-way setup on the developers of the product but we're still having this discussion for some reason.
