Neumann KH 150 Monitor Review
Rate this studio monitor
    Votes: 0 0.0%
    Votes: 3 0.6%
    Votes: 42 8.8%
    Votes: 435 90.6%
Karmacoma
France
One extra conversion is quite a bit less than 50 so there is no chance at all that you could hear any difference.
Thank you for your answer, I was misled by the use of an hyperbole regarding the context.
Karmacoma
France
Just ordered them, then i went to read the full specs on Neumann's site.
Fell on a very californian mention.
''WARNING (for California residents only): This product can expose you to chemicals including lead, which is known to the State of California to cause cancer and birth defects and other reproductive harm. For more information go to: www.p65warnings.ca.gov.''
Translation: DO NOT EAT THIS SPEAKER
Elder
What's the chance they're gonna make a Mk2 version like they did with the KH120?
The KH150 is from the same generation of tech improvements as the KH120II. You can see the original KH120 was availible for a very long time before a refresh.
That's all anyone knows. One thing I do know though is you will drive yourself crazy always waiting for the "MK2", as that will turn into the "MK3" etc etc. Progress never stops, just buy what will be sufficient for your needs and make you happy today IMO.
formdissolve
USA
Yes I understand that now. I was under the impression the 150 was out for awhile, hence the question, but since I got 3 responses saying otherwise we can all ignore it now
unpluggged
KH 120 II is the 5" version of the KH 150.
formdissolve
USA
Yeah am aware of the size difference, but was just wondering because according to Neumann the KH 150 uses a 24-bit DSP while the KH 120 II uses 32-bit with 64-bit floating point for the DSP. Made me wonder if the KH 120 II had newer tech in it. For my room size and listening habits, I will be going with the smaller 120 II's with maybe an upgrade path to 150's in the future.
If either sound as good as my baby KH 80's I'll be quite happy!
Pearljam5000
Well, I used these for listening to music in a not-treated living room. They sound nice for sure. But for my use I noticed too little difference compared to my Mackie MR 624’s to justify the steep price. I returned them.
Well that's surprising
Maybe you should try some Genelecs instead
Infinit0
Have you used the ma1 for calibrate your room? If you havent noticed diff is prob of your room then. You listened to your room not to the monitors.
DJBonoBobo
any germ
I don't know measurements of the 624, but other Mackies are not bad, though.
I agree with the room-thing, but maybe the difference really is not that huge. Depends on how you use them.
Pearljam5000
The KH150 is supposed to be one of the best monitors on the planet and on the other hand there isn't a big difference from a budget monitor ?
How does it make sense ?
cyjanopan
*one of the best monitors on the anechoic planet. Then you put it in a room and half of what makes it so good is drowned in reflections, SBIR, room modes, placement and expectations
DJBonoBobo
any germ
+ they are all just speakers, not magical pleasure devices like some reviews suggest (i think that is what you meant with "expectations").
boxerfan88
And I wonder who gave the KH150 the title of "best monitor on the planet" ? :facepalm:
cyjanopan
exactly, especially flat studio monitors are somewhat unimpressive at first glance, as they excel in what they don't do (distortion, very wide dispersion, boosted frequencies etc.)
