MT_bassbone
- Joined
- Dec 22, 2024
- Messages
- 87
- Likes
- 19
Neil Blanchard MLTL-6's. Anyone have experience with these? The measurements look decent.
Would you consider this good? It looks pretty jumpy by my eyes, but I am just an amateur.Here's the same measurement but in a more normal aspect ratio:
1/24th smooting applied to get rid of some digitization artefacts.
Rednaxela is right. If you follow ASR then you would know that a single on-axis in-room measurement is not enough data to have an opinion on a speaker.Would you consider this good? It looks pretty jumpy by my eyes, but I am just an amateur.
If this is quasi-anechoic, then it's pretty bad.Would you consider this good?
Can you post the graph with Psychoacoustic smoothing? That 5kHz peak "looks" bad but is quite narrow and maybe not very audible.Here's the same measurement but in a more normal aspect ratio:
