Neighbors air-to-water heatpump causing disturbing noise, any advice?
Nick4191
When it's cold outside, under around 2 Celsius (35,6 Fahrenheit), our neighbors air-to-water heatpump that is located 5 meters (16,4 feet) from our 2 bedroom walls, creates a disturbing rumbling noise that affects peace and sleep inside our bedrooms, even with the windows closed. The unit in question is a Mitsubishi ZUBADAN R32 (air-to-water heatpump), Model specification: PUD-SHWM100YAAR1. The issue is apparent during cold weather, and during the summer heat when windows are open. At these times the unit is working extra hard on high RPM and high effect, which causes it to generate a lot more noise.
dB measurements with a calibrated sound meter, when the issue is apparent:
1 meter (≈3.28 ft) in front of the heatpump-unit reads 69.8 dBA and 81,7 dBC
right outside bedroom window is 52.9 dBA and 67dBC
Inside bedroom 50.7 dBC
Here is a recording of the rumbling noise from inside one of the bedrooms with the windows closed. Many speakers aren't able to play much of the low frequencies, if you play it on your phone speakers or cheaper end headphones, it's not going to be a good representation of the real noise:
https://jumpshare.com/share/YltTtCX40YX9pgHgaVWD
Also included as attachment (Air-to-water heatpump noise inside bedroom - without EXIF.wav)
Here is a frequency and loudness graph of the recorded noise. It shows how loud different frequencies are:
Also included as attachment (Noise profile - without EXIF.PNG)
Anyone else have experience with a similar issue? Anyone have any advice on how to go about blocking this noise, would a concrete barrier in between the source and our house be a good idea?
I'm presuming your in the States, in my country after 11pm anything over 65 DBA (measured from inside the house with windows open) is illegal and I am sure its similar in many places around the world. Check your local council regulations.
In terms of what else you can do, I would put double glazed Euro windows with the largest air gap between the two panes with one pane at least 10mm thick. Although that won't be very effective against the low rumbling noise it can mitigate it a little which might be enough, don't take my word for it though.
I'm not an expert on DBA, DBC, DB but from my understanding DBA omits/levels out the low frequencies and because the frequency reading is all low frequency content the DBA measurement is lower than the DBC and DB and most of these regulations are in DBA.
Regarding your question per se I'll let other chime in.
If it’s a similar device to mine, it has a silent mode that one can enable at night.
You can also buy shrouds that direct the sound upwards.
The thing is that it's the neighbors heatpump. Maybe they are willing to use silent mode during the night?
What type of shrouds are you talking about? Do you have a concrete example of a product?
Yeah, will have to check local councils regulations. I hate having to take such matters up with a neighbor but such is life. I'm actually in Finland.
We already have double windows.
You got it. Most regulations are in dBA yes, there is dBC regulation in my country too though.
Thanks for replying with what you know.
If it's not already on anti vibration pads, that might help a little. They are rubber/foam squares that go under the unit. You could ask your neighbor to install some. I also think a shroud / barrier would help.
These heatpumps are becoming a menace, now in my area I sometimes hear them on new builds - at first I mistook it for someone leaving their hot-tub pumps on.
I would echo the above - if you can build any deflector or brick wall to direct the sound upwards, away from your windows, then that's the way to go. If the neighbour is reasonable they may help in your quest to stop this noise nuisance too.
After deflectors and a wall, hedging might help too, but for low frequencies you may need somethig heavier and closer to the noise source.
From what I've seen, many heatpumps are installed and adjusted very badly so they roar away continuously, soaking up electricity for very little effect - it may be that a decent engineer can bring him far more efficiency and you a lot less noise at the same time.
Visit and talk to your neighbor in a friendly way, and ask if she would join you to listen to the unit at the unit and in your home. Ask if they can do something to make it quiet. That is first step. Following steps depend on how she reacts.
I live in a "mixed-use residential area," where the permissible noise limits are 55 dB(A) during the day and 40 dB(A) at night. Since the other apartment owners did not consent to the installation of a fixed split-system air conditioner, I have opted for a semi-mobile solution instead. The added enclosure serves as protection against both the weather and noise. In eco mode (500 watts), it is barely audible—even at close range—though it does get quite loud when running at maximum cooling capacity. I plan to pair it with a balcony solar system this summer—and I can already hear the neighbors cursing. :p
Is there any data or information on how that enclosure mitigates noise?
Anything with a fan and/or a compressor will generate noise.
You have 3 choices, not necessarily all viable: 1) Move, 2) Nicely ask you neighbour to deal with it with suggestions from above or 3) Contact any local environmental health agencies in your area - in the UK at least, they can come and measure/record noise nuisance and take action if above limits.
I would check the local regulations first. Measure noise properly and compare to what's legal. Use that as a base for discussion.
Behind my house I have a large AC split unit. To not create such a problem it is properly isolated from ground and walls. And for night hours programmed to run rather silent and continuous. Heat pumps should have some options too I guess. They are everywhere now and often pretty near to other peoples walls/windows.
