I live in USA and have to avoid too much noise due to a severe ear condition, which is impossible with how loud the people I live with are, and how thin the walls are, plus a gap under my door that easily lets even more noise in. Since it seems as though there’s no way I can soundproof all of my bedroom (165.5 sq ft/15.37 sq m), with how much I think it would cost and how much airflow I think it would cut off, I’m thinking of setting it up so I can use my PC in my closet (15.17 sq ft/1.41 sq m). The problem I have is that I have no idea what soundproof curtains to get since I don’t know anything about them between brands, material, thickness, sellers, things like that.
My idea is to attach the curtain to the shelf above and just let it drape over. The distance up to the shelf is 85”/215.9cm, and going across I would need at least 85”/215.9cm, maybe more than that so it can also cover the wall in a U shape.
I also can’t figure out how to block out as much noise as possible without cutting off too much airflow since it makes my asthma worse from the lack of oxygen, like how leaving an opening at the top of the curtains would retain the airflow, but it might let too much noise in.
I was also thinking that multiple curtains to just layer on top of each other might be a good idea but I’m not sure. I’m just hoping to find out what the best curtains and methods would be, or maybe if anyone has better ideas on what I should do, so I’d really appreciate any help.
