If your DAC has a USB input (most do) and a WiFi connection to the internet, you could consider a used or refurbished iPhone 6se (or 7) with the camera lightning port adapter. The phones are avail from Walmart resellers for $60-$110 or so. The cable is ~$40. This is currently what I'm doing with my Tidal subscription.
If you're looking for "plug & play" and support for TIDAL Masters (MQA), this is the answer. To go above 24/96, your external DAC will need MQA support:BlueSound Node 2i
If the DAC has a USB input you could use a Raspberry Pi as the streamer. I doubt there's any networking ability that audio-specific streamers have that a Pi can't do just as well.I'm interested in wired only...
rasperberry piWhat's your recommendation for a wired streamer that connects to the internet that I can use for Tidal?
The streamer will connect to my DAC via digital coaxial cable.
I looked at these 2 so far...
BlueSound Node 2i
Cambridge Audio CXNV2
It's a tiny (credit card size) SBC (single board computer). It includes all the hardware you need to run a music streamer, and can also be connected to a TV via HDMI.Thanks! I've decided to use my PC instead of a streamer.
The PC sits about 20' from the DAC which has a USB input.
Is this length too long?
What is the purpose of the Raspberry Pi? and can I install it myself?
Just use a decent (but not audiophool) usb cable from your pc to your dac, and that is all. Software depends on what you want to play. I use my study's desktop pc to play music into a usb dac, and I have two sources: TuneIn for internet radio and Spotify premium for music. These sources provide the necessary software, so nothing additional is required. Even a very basic pc will be fast enough.
The limit for USB is 5 m (~16 ft) unless you use a hub.Thanks! I've decided to use my PC instead of a streamer.
Any upgrades to PC required to use as streamer?
No upgrades are required for any recent computer, but you will need to choose an app to play the music. Is the music on the PC or a NAS? Are the PC and DAC in the same room, so you will be using the PC for other things while listening to music?
(Edited to make more sense, I hope!]
I'm not sure about USB over that distance. You need a hub or repeater to go over 16' and I don't know how well they work with audio. Is there any way you can reduce the distance, such as longer interconnects from DAC to amp?Will be streaming thru Tidal or Qobuz.
DAC and PC in same room but 20' apart.
PC is for work and personnel use.
Edit: I might be worrying about nothing <http://archimago.blogspot.com/2013/04/measurements-usb-cables-for-dacs.html>
Does a Windows PC output audio via USB unprocessed?
In WASAPI Exclusive Mode, yes, if the bit depth and rate are the same as in the Sound properties. If not, it will do a resample to the set depth and rate - I'd not concern with it though as any artifacts from the process should be down so low in the noise floor as to be unhearable...
