i Just bought the Apos Gremlin amp and the DT 770 Pros and need cables and adapters. This is my first time using equipment like this so i could use a little help.
i was looking to find a adapter for my headphones to the amp, which i found this https://www.amazon.com/gp/product/B075165H2M?smid=A2OPUAQVSPCTA3&th=1 adapter Is this okay? Too cheap?
my next cable is for the amp to go to the pc itself. i can either go for the 4.4 mm route and go to usb or get a dual XLR to usb cable. i was thinking option 2 and getting something like this https://www.amazon.com/Devinal-Outp...e&qid=1772309509&sprefix=,aps,148&sr=8-5&th=1 Same thing for this. Too cheap? okay? My budget is not high at all, my max is $80.
Any help would be appreciated
Thank you
Thank you
