I am at a lost to understand/explain how the averaged surface temperatures of the March case and the Ghent case can be very different, when given the same external environment and same heat generation. The external geometries of the 2 cases aren't very different. Their total surface areas are almost the same. What I am saying is the March design is better at letting the heat from the Hypex modules transfer and distribute to the case. From the case to the room air, the March and Ghent designs are similar IMO.These are interesting details.
There are a few things not aligning in my mind:
- if March case cools better by conduction, I would expect it to be hotter in the same conditions, seems not to be the case (pun not intended but self appreciated)
- as already written, the SMPS1200 and the NC1200 dissipate a good proportion of heat in the air, and in this situation a higher thermal mass and lower surface of vents may not be an advantage.
- as you write, both cases are not optimized for cooling, they even have an insulation layer between themselves and what they are supposed to cool. How can one be much better than the other?
When we use the electrical analogy, the average case temperature is V_in, room air temperature is V_out, thermal resistance for convective heat transfer is R, and heat flow is I. Ohm's law also applies here (V_in - V_out = I * R). When R, I and V_out are fixed, V_in is fixed too and cannot be different between the 2 cases.
If the "system" has reached steady state, which it should be after a few hours of idling, the different thermal masses shouldn't matter. Hard to imagine the tiny holes in the top cover of the VTV (Ghent) case will make much differences for natural convection.
