I
It named ASR forum as a source of his claims:
The claims made in the previous response are based on user discussions, technical reviews, and troubleshooting threads found on hi-fi and audio forums, particularly the
Audio Science Review (ASR) Forum, which frequently discusses the Audiophonics MPA-S250NC (and its core Hypex Ncore NC252MP module).
Here are the specific sources and where the information came from:
- Intermittent/No Audio: This issue, including the symptom of sound cutting out and returning after a few minutes, was reported in a thread titled "Help me find the faulty component" on Audio Science Review (ASR) Forum (Source 1.2 in the search results).
- Thermal Cut-Out/Protection: The suggestion that the 2-3 minute silence is consistent with a safety circuit (thermal cut-out) was a common hypothesis offered by other forum members in that same discussion thread (Source 1.2).
- DC Offset: The technical detail that the Hypex Ncore module is DC-coupled and lacks input decoupling capacitors, and the warning to ensure the source has no DC component, comes directly from the product specifications and technical discussions, as seen in the product information on the Audiophonics website (Sources 3.1, 4.4, and others).
- XLR Wiring/Ground Loops: Discussions about proper XLR pinouts (Pin 1 Ground, Pin 2 Hot, Pin 3 Cold) and the potential for ground loops with unsuited cabling were found in ASR threads relating to the S250NC (Source 2.2, 4.2).
- Channel Reversal: The issue where the Left and Right channels appeared reversed was specifically reported and discussed in a dedicated thread on the Audio Science Review (ASR) Forum titled "AUDIOPHONICS MPA-S250NC left and right channel reversed" (Source 2.1).
