Need integrated amp: 100 W+ into 4 Ω, headphone amp, ≤€1 k, SINAD ≥100 dB
Thanks for the thoughtful replies, everyone – the thread has actually helped me boil the question down to two concrete paths.
1.
Keep the Teufel Ultima 40 Mk4 and buy a €400-€500, 150-200 W/4 Ω, SINAD-clean class-D power stage (Topping PA5 II, 3E Audio 250-2, Fosi V3 Mono, etc.).
– Cheap, measures well, plenty of head-room for these speakers, no headphone section needed because the DX5 II will already cover that.
2.
Send the Teufels back, raise the speaker budget to €900-€1 000 and mate them with a €350-€400 integrated (Yamaha A-S701 or the new WiiM Amp Ultra).
– Gives me a demonstrably better transducer, but I lose the raw power the class-D blocks offer and, with the Yamaha, I drop 15-20 dB of SINAD.
If I stay with the Teufels I know I’ll enjoy them – I’ve already heard them in a mate’s place and they’re a big step up from the Panasonic micro-system I lived with for so many years.
The “buy better speakers first” argument is absolutely valid, yet swapping boxes again means another month of couriers, repacking, and living with TV sound while I hunt for the next candidate. At 51 I’d rather start listening now and upgrade later when I’ve learnt what I actually crave in a speaker.
So, unless someone can point to an integrated under €1 k that simultaneously:
- does 150-200 W/4 Ω with good current delivery
- keeps SINAD ≥100 dB
- remains a valid choice for the time I choose to upgrade the speakers and buy the better ones
…I’ll take the first road: keep the Teufels, add a clean class-D power amp, and run the DX5 II for headphones.
If that chain still leaves me wanting in a year or two, the amp will happily drive whatever fancier speakers I audition next.
Does anyone see a hole in that plan – reliability issues with the Topping/3E/Fosi boxes, fan noise, ground-loop gremlins, anything? Real-world feedback is appreciated; paper specs only tell half the story..
I need enough clean power on tap that the music never sounds squeezed—big dynamic jumps, bass that punches without bloat, and enough headroom that I can turn it up to “live” level.
I’m told the heavier the transformer, the harder the amp can hit when the music demands it—more punch, more grip, more headroom...
You do NOT need 100dB SINAD or better for terrific sound, it's far from the most important criterium. 90 is easily good enough, as long as it's powerful enough.
400-500 for a poweramp... that already gets you into Hypex territory. NC252MP for example, 96dB (super clean) and 2x250W peak. Killer amp for home applications. Remember: 96dB SINAD means you can play 96dB music (very loud already) and hear precisely zero distortion and noise. Except speaker distortion of course. It's so "bad" it'll mask anything else from the electronics. ;)
I get it mate, juggling heavy boxes around and returning and whatnot is a hassle. But you'll only need to do all of it one time and then enjoy the stuff for long years. That should be the goal: long term enjoyment, buy once, cry once, do it right and it'll be great. Speakers are crucial for that. Trust me, for not that much more you can get MUCH better ones. No amp in the world can compensate for that.
Don't fixate on the SINAD too much. You won't hear the diffrence anyway. As for alternative speakers, you may consider KEF Q7 Meta if you can stretch the budget a bit. Or maybe Q Concerto Meta and a nice subwoofer.
Most of the amps on your list have an SMPS, so no large transformers are to be seen there at all. In general, though, it's mostly a marketing fairy tale anyway.
I own three integrated amps of widely varying power output and SINAD performance, and a couple of high end power amps that do very well all round. I suggest you relax your SINAD requirements and your power requirements, or increase your budget well beyond 1K Euros (or consider second hand). There is nothing wrong with getting the “last amp I will ever need”; I’ve done it several times already. ! But the amp will not be the limiting factor in your system. That will definitely be the speakers. I have not had good luck with Topping; I got a DAC and a headphone amp, and both failed after a year or so. However it is unlikely that you will find a good HPA in an integrated amp at the budget levels you are considering, so a separate unit is still a good idea. Personally in your position, I would go for the Yamaha, or something similar (I have a 15 year old Rotel that has a very average SINAD, but cranks out way more than enough volts and amps for 87db speakers). You will get many years from something like that, and you can plan on a speaker upgrade at your leisure. (It will make a big difference, believe me!)
I would definitely get something with some kind of room correction or advances EQ possibilities. Next to speakers, that will be the biggest impact on sound quality. WiiM amp ultra is a no-brainer in that regard.
I'll agree with a lot of what has already been said, and I respect your choice not to replace the speakers and start again (technically better but a huge hassle)
Don't fixate on SINAD, it doesn't make a practical difference as long as your electronics are quiet enough.
You have a very good streaming pre-amp in the WiiM Ultra. You don't need an integrated amp (with its own preamp), just a power amp.
A separate headphone amp, as you are considering, makes good sense.
"heavy" transformers are just heavy ... ignore all that audio nonsense
Pick something that you feel good about: the Yamaha A-S701 (I know its integrated, but hey) is a robust choice. The WiiM Vibelink is also good, and a nice match with your Ultra. Otherwise, pick one of the Topping/3e/Fosi options and you'll be happy. I like the idea of the 3e units, but don't have practical experience
Don't overthink it, you'll be fine
Here’s a thought: JeremyFife made me think that if the OP is ok not having an integrated amp and just using the control part of his existing WiiM Ultra then with only a little stretch of his budget he could go for the boXem that was recently reviewed here by amirm. A very fine power amp that meets ALL his criteria with room to spare, and as the OP is in Europe, it is also made locally.
Hm. It would also drive any speaker OP might get in the future. Not bad an idea.
On a smaller budget, Audiophonics also makes some power amps using various established Class D modules. They are less stylish and not as nicely put together as the BoXem ones. Any of them would pair nicely with the WiiM Ultra and offer room correction.
Taxes and shipping cost corresponding to your country are calculated at checkout. I live in Italy and the price shawn is €1,415.20. Out of my league guys....
Yeah that's steep. But fear not, as @voodooless suggested, there's way more affordable alternatives. Here's two:
Just two options. Both will make short notice of your speakers, and also drive more demanding ones if you'll eventually get some.
AUDIOPHONICS MPA-S250NC XLR Power Amplifier Class D Stereo Ncore NC252MP 2x250W 4 Ohm​
What's the difference between XLR and RCA version and how it affects to my system?
The difference is just the input connectors. There might be a tiny improvement in noise with XLR, mainly coming from cabling. Negligible.
If you only have RCA (unbalanced) sources anyway, choose the RCA version.
WiiM Ultra → Topping DX5 II → Audiophonics MPA-S250NC XLR → Teufel Ultima 40 Mk4.
Is this a clean, balanced path all the way? If yes, when the time comes I only have to upgrade the towers.
That's about as clean as it gets. And futureproof indeed.
Thanks, everyone—I’ve decided to go for it. Audiophonics MPA-S250NC XLR
Dayton a400 and a headphone amp.
On paper the two amps look alike, but the price gap right now is huge:
Yamaha A-S701 was €549 only a few weeks ago and is still hovering around that figure on Amazon.it
Dayton A400 is listed at €850–€999 once you add shipping and import duty from the only EU-friendly seller becomes almost double the Yamaha.
For that extra money I get roughly 3 dB more head-room (≈ 300 W vs 160 W into 4 Ω) and balanced XLR inputs, but I'll lose the remote, built-in DAC, phono stage and five-year dealer network support that come with the Yamaha.
Yep, that’s why I suggested the Yamaha. At €549 it’s a snip. But the Audiophonics with the correct spec is sound too!
Both great options mainly differing in features. The Dayton, hm. Seems overkill for this use case, especially the bridging option. Nobody is going to use 600-1000W in a living room, unless it's huge and speakers can do it... expensive lol. And as already said, at that price there's better alternatives - which are also overkill. :D
I have bought and played with Wiim and Fosi at home, but in the wider scheme of things they’ve only been around moments. They are brilliantly novel, but have no track record. My long term kit is Marantz, Linn, Primare, Pass, Tascam, ATC, Sonus faber, and such like, all with good pedigree.
Just want to push back a bit on this condescension re playing with toylike WiiM and Fosi products and instantly jettisoning them, and the elevation of brand longevity and “pedigree” as gold-standard criteria in the year 2025.
I’ve evolved from Sony ES and Musical Fidelity integrateds to a current lineup that includes WiiM, SMSL, and Fosi amps. I’ve been somewhat amazed that my sound seemingly hasn’t lost a step in performance at a dramatically lower cost — so far so good in terms of reliability and a bunch of innovation and versatile features that are thrillingly up to date. Nothing to make me feel I’ve been imprudent or rash or should be relegated to the unserious kid’s table.
