I just got my spanking new Topping D50s. Looks cool.
I got it all hooked up and....NOTHING.
It turns on, the controls work, but absolutely no sound. Yes, I turned the volume up.
I was really looking forward to using its bt connect. Nothing. My player plays but nothing comes out.
I tried using USB to no avail. Same problem.
Normally, I use my lg v50 with 3.5mm/rca adapter as source because its quad dac is pretty good.
My phone is on the cd input and my bt(now the d50s)had been on the aux input of my pre. Strangely, if I turn on the D50s while using the aux in, the aux in cuts out even though the D50s itself is connected to the cd in.
I've checked and rechecked connections.
Any ideas.
Any ideas.
