Hi everyone,
This is my first post here. I've been reading forum topics for a long time and I really like this place, for which I thank you!
I'm helping someone to find the problem with incorrect acoustic measurements and soundcard calibration in REW and I'm wondering if any of you have encountered similar issues.
I don't have access to his measurement setup because I'm helping him remotely.
He's trying to make gated measurements of a 6.5" mid-woofer and 1" tweeter mounted on speaker cabinet, measuring with Dayton imm-6 mic and PC built-in soundcard. Here is what I've observed so far:
1. Soundcard calibration has a linearly rising +6dB/oct response. I expect overall flat response with some roll-off at lower and higher frequencies.
2. On the IR graph the first pulse looks strange - IMO, not what is expected from a raw woofer. If I remove the soundcard and mic calibration files and gate with a window over the first pulse I'm getting also a linearly rising +6dB/oct response similar to the soundcard calibration file.
3. The second pulse on IR graph looks correct and if I place the gating window over there and also remove the calibrations, I get similar to the expected woofer response.
4. Tweeter measurements have similar issues.
I expect to see some reflections on the IR graph after the main pulse but I'm puzzled with the first pulse and the soundcard calibration results leading to a rising +6dB/oct response. Personally I'm measuring with EMU0404 USB interface and ECM8000 mic from years, and have never observed something like that. Has anybody seen similar results and what could be causing them? I'm attaching some screenshots from the incorrect measurements.
Appreciate your help!
This i
This i
