Hi everyone! I'm new here but have been reading the forum for a few months now. I have to admit that I am a noob and don't know that many specific terms, etc. I would welcome any help there is.
For a number of years I've been using the same setup for my PC. Mostly I play competitive games, listen to music (various genres, but mainly rock or electronic), so that's going to be the primary purpose of my setup. Music I listen on Spotify. Hopefully Tidal, when they finally get to my country. In terms of sound, I'm not really sure what I like. I just don't know much. Probably a bit warmer? Though I'm not a basshead, sometimes I enjoy vibrations from low frequency. So correct me here pls, I assume something balanced would be the choice. And I can't really just try stuff out. So it's basically I get what I order; not much chance for experiments there.
Currently I am using:
- What decisions are already made:
- Next is what to use with PodMic.I can still keep Scarlett for it, but ideally I would replace it with something. Any ideas here? Haven't researched it yet. Went with the Focusrite Vocaster One. It was a great price on discount and has over 70 dB of gain, which is perfect for my Podmic. I had to run it on almost full gain on Scarlett, which had
significant noise. I will be using it only for the mic anyway, so it should be sufficient.
- And after that, would be good to get new speakers and an amp for them. I like my Edifiers; they are pretty good for their price. But i was already feeling like buying a sub for them, so decided maybe it's time to just upgrade them completely. Haven't settled on new ones yet, but from research it looks like amirm highly praised the Elac Debut Reference DBR-62, so potentially them. But they are kinda pricey. And I don't know yet if they will need a sub. In terms of amplifier, people here seem to love the Fosi ZA3. // Since I'm going for ZH3, it makes sense to keep it paired and get ZA3. However, I'm open to any other suggestion.
So at this point the question is: Do i keep my active Edifier speakers and get a sub for them, or Do i switch to passive and get new speakers + amplifier.
1. It's a matter of sub than. Should i just get Edifier T5? I assume it should have good synergy with my speakers. Or smth else?
2. Should i go for Elac Debut Reference DBR-62 or smth else? With an amp, I'm pretty solid with ZA3, if it is sufficient, of course.
I would really appreciate any feedback and suggestions.
- Focusrite Scarlett Solo 3rd gen
- V-MODA wireless 2 closed headphones
- Rode PodMic
- Edifier R1280DBs active speakers
- I would definitely keep the PodMic; it's great. I love how it looks, and sound seems pretty good to be. Not even talking how tanky it is.
- V-MODA is getting replaced by Fiio JT7. I've spent tons of time researching and decided to listen to @solderdude and get those
- Fosi ZH3
Fosi K7- Topping DX5 II
- Fiio K7
Fiio K11
