Need help with my PC audio chain. Planning, understanding and critic
Marius336
I guess I should have come here first, befor actually buying half the gear, but better late than never?
I have a desktop system I build around. So headphones and near field. Started with headphones only, now I'am basicly expanding that system with monitors. Location Germany.
I need help in evaluating the technical aspects of the chain. Not soley in what you can hear, but messurable between the devices itself and confirm their functions, because I basicly worked with gemini to design this over a few months and having it make up stuff every other corner, contradicting itself on features and their effects on the signal. So could be a few errors in this.
The planed chain:
- Audirvana on Windows-PC, upsampling to 96kHz 32bit
- ASIO into a virtual audio input of a RME HDSPe AIO Pro DDC/DSP PCIe card
- Toslink S/PDIF @96kHz 24bit to a Trinnov Nova room correction processor
- AES/EBU @96kHz 24bit to a Holo Audio May KTE R2R DAC @ NOS
- XLR to Holo Audio Bliss KTE AMP, parallel to that RCA from same DAC to Yoshino EAR 868L tube preamp, XLR2 to the same AMP
- 4-Pin XLR to Meze Audio Elite planar headphones
- XLR to Geithain RL 944K1 coaxial, cardioid, active monitors.
Add some room treatment on top and you have the plan. Now I do not have the monitors, the tube preamp (more like a place holder), and the DAC is currently a Holo Audio Cyan 2.
Now the challenge with this is: I wanted my gaming and media PC-setup to do a few things that dont go well together:
- PC as an audio source
- purest digital signal possible (bit perfect, if we ignore that I want DSP to actually do with the audio. basicly remove windows from the chain as much as possible, no resampling/asynchronous reclocking, just add what is nessesary and not more)
- DSP obviously for room corection, volume normalization, EQ, upsampling and mixing. Wich contradicts the point befor as you may noticed
- hardware (remote) controlled. basicly some nobs to turn instead of mouse in programm window
- clean but "soft/warm" sound, not fatiguing
- nearfield, like listening distance around .9 to 1.5 meters, near a wall, in a small room
So why did i choose this and what do i think it does.
Audirvana obvioulsy upsamples. Settings are: Minimum phase to supress pre ring, niquist band width 96% to give the filter some room, cutoff band attenuation 167,3dB. Since the signal will be 24bit later, wich is ~144.5dBFS, it needs to be above that. the question is, since there is still information as low as -15dB to be heard below the least significant bit, i gave a bit of headroom. No idea if the PCIe card recieves 32bit and dithers it for itself befor or after the internal processing. Audirvana doesnt alow for bit depth setting in my case. I let it upsample to 96kHz. Now theoreticly 192kHz could be possible in the future, wich would help, since I aim for NOS mode to make the high frequency drop even less shallow and give more headroom for the imaging etc?
RME HDSPe AIO Pro was the hardest to find part. Not because of rarity, but what I need it for. I came across it fist as a UBS eliminator, then realizing that it was in fact the missing piece. The direct memory access, circumventing the whole USB stack and 8k pulling rate load spike and whatever is cool, but since it has a FPGA for mixing in 46bit fixed point, I could finally get away from the gaming mixer I had prior, bottelnecking the entire chain. Since I game and stream, I not only want my music, but other audio too on demand. Most of the time, that is done in windows and most likely WASAPI. The RME has Total Mix and I can connect a midi controller of my choice. It also features a femto clock and FIFO buffer with PLL, if I where to connect another digital source, or use the word clock module. But since its not 10MHz, but the actual clock rate, I could only use it with a Mutec MC3+ USB or one other discontinued DDC. The Toslink galvanicly isolates the PC from the audio gear. My original plan was to put both on different electic phases + install shielded wall cable (NHXMH-J (st) 3x2,5mm² is like a few cent more expensive per meter) to isolate further, but that is heavily tied to where I will be living in the end. Is it stupid? Probably, but against the rest here its only a minor expense if you can install it in a freshly build house.
Tinnov Nova is another example of AI problems. First I had ARC Studio (extra conversion, I could notice the quallity loss), SoundID Reference, lastly MiniDSP Flex Digital and SHD Studio with Dirac. The problems with the later, was a very poor remote with the KD-1, not the best room correction and the internal asynchronous resampler at every input (even USB I believe), wich would have a noise floor of somewhere around -130dBfs? I know you cant hear that etc, but it bugged me. The Nova on the other hand can completly get it out of the chain and synchronise to the source, also having a FIFO and PLL. It may or may not get an update enabling 192khz too, but for now thats grayed out. Toslink is known for having a bit of a problem with such high frequencies, but as far as I tested, my configuration works going directly into the DAC. The La Remote it comes with is very nice to use and I dont have a glowing screen all the time with a bad menu structure. The second downside is: It has one digital output besides Dante over ethernet, so if I where to connect some subwoofers (Geithain Basis 11K / 11KP), I would ether be resticted to position them in the same vertican axis as the monitors, or conncect directly to the Nova via XLR. Since 80Hz and lower dont really benefit form NOS or tubes I assume, the later would be best to let the Nova do its job propper. Futhermore I can choose between a software and a hardware bypass, if I dont want/need it. Lastly how do I actually use it? I guess you would want do to most with physical room treatment and let it handle everything below the schroeder frequency for the room?
Holo Audio May KTE i can probably skip, together with the Bliss. What I want from it is NOS. Iam definitly not doing DSD, as I need my GPU for frames, so PCM it is. I like the sound, thats it. What is interesting is the optional PLL, but my knowledge on that is vague when it comes to downsides. It would indeed clean up the signal from the Nova + whatever happens on the way and since the master clock in the RME is decent, I would assume the drift is pretty constant, making its job even easier. But it might not be nessesary in the first place, since the Nova already handles what jitter the Toslink produces. Would be interesting to know, what gets introduced by that in return. Also the AES/EBU length matters because of signal reflexions at sub 1.5m?
Holo Audio Bliss KTE sounds nice, class A, has the connections I need. Now the thing with the parallel tube preamp is tricky. Its an idea. Nothing is set yet and it would be the absolut last piece I test after everything else. The reasoning is, that I have the option to bypass it for gaming, media and home office. Now the EAR has like 600Ohm inpedance output and the Bliss 6200 Ohm at the RCA and 12400 Ohm at the XLR, which should work for the XLR, but Iam unsure if the 1 to 10 ratio on the RCA will be enough, if its lower at specific ranges than on paper. But the May only has one set of XLR and I want an internaly unbalanced preamp, since i get it for the 2nd order harmonics. So that could introduce a ground loop? I dont know how much of an issue that is and if I should go full XLR into the preamp and RCA on the bypass, or desolder the ground pin from the XLR cable on the bliss input side to the preamp. I choose the EAR 868L specificly for the XLR Outputs. Other options include the LAB 12 PRE 1, but again, I do not know if I want that component in the end and what to do about the potential ground loop issue.
Geithain RL 944K1 is a pretty interesting monitor. Now the challenge is to find something that is analog to actually hear my chain, can be used in a near field at 1m listening distance and doesnt kill me with base in a small room, while having a wall behind it. Or at least gives the Nova a simpler job. There are other options, that have a more traditional layout I looked at. PSI Audio A17M/A21M to name two. But a coaxial would alow for more drivers (3 instead of 2) and the K-technologie for a more linear bass in a small room. I have not heared it so far, but at least on paper it seems the best choice I could find. The K1 variant brings the weight down to 15.5kg and saves on depth with an external unit for the power amplifier and crossover.
The Geithain Basis 11K would compliment that if needed with the same technology, offering a mono and stereo analog high pass at 60 or 80Hz, with a optional passiv variant KP, that is powered by the standard unit as slave. But I do not quite understand the benefit of a slave, if you cant separatly controll it for a true 2.4 system. What does stacking them vertically give you other than more surface area?
I also debated DDC reclockers for a while, but since every digital device in the chain basicly has its own internal, that would be redundant. What I would like to read up on is USB asynchronous audio vs S/PDIF. What Iam I actually gaining by eliminating it in the chain on a fundamental level? I want to know what happens to the digital sample as detailed as possible out of pure curiosity. Like truncation vs dithering kind of deep.
So there you have it. Let me know what I missed, errors and what you would change. I dont really have a hard budget, but Id rather stay away from even more expensive gear if possible. But you can mention it anyway.
It's hard to unravel this - it's somewhat mythological to my mind, and sounds expensive on an ongoing basis :)
What are the sources of the music you play?
There's a lot of unnecessary stuff here. If you have been paying for Gemini I suggest asking for a refund.
Let me put it this way - what will actually sound different if you do EQ on the computer and send a digital signal straight to a pair of Neumann KH80 or KH120? The speakers, that's all.
You won't hear any difference from 'the chain' as it's all high performing analog or digital equipment.
The only difference in synchronous vs. Asynchronous in this case will be which device handles the clock. Since most DACs use a buffer anyway, even that is irrelevant.
Looking for sound quality improvements in digital equipment is like trying to improve the plot of a book by using a better printer, it really doesn't work that way. Typically once the bits leave the source they stay the same for the whole journey. There are plenty of people who will sell you sometime that suggests otherwise, but they are generally lying or solving a problem you don't have.
Might be better if you ask specific questions.
AI has led you down the garden path. I would trust random YT influencers more.
I have been doing PC audio for decades.
The main thing is to get the best external DAC you afford. Other than that it is similar to the needs of other music players and components.
You need good software, I am OK with JRiver, but there are free ones that are good.
FxSound is free and a very good addition.
You can get a perfect DAC for next to nothing. Spending big bucks on a DAC is as unnecessary as spending big bucks on cables nowadays.
Totally agree, the mid tier topping stuff is beyond audible issues, RME makes stuff that is excellent in both features and sound quality, other brands offer similar sound quality (I.e. effectively perfect) with different aesthetics... In the end it's hard to think of a reason to spend more than $1K on a stereo DAC and it's very easy to spend less without missing out on anything.
Tidal and Audirvana. 44.1 to 96kHz 16 and 24bit FLAC. A few MP3s here and there.
Fair. Trinnov and Neumann both do IIR and FIR, phase and time correction. I hahe only tested the other softwares, like IK Multimedia, Sonarworks and Dirac, that lack some of these features. The 3D aspect and specific way the DSP is calculated is the only difference sticking out to me.
Humm
1. most onboard audio chip on modern (last 10y) motherboard are good enough (aka no audible issue) and most support at least 5.1. Audio on Mac is excellent. the headset pre-amp is usually not great on pc motherboard but it is good.
2. a perfect (in the sense no audible issue) stereo DAC cost a good 100$ top, pick yours in the long list of positive reviews here on ASR. investing more is really not useful.
Pierre
Yea its a lot to unpack
I think there are two hardware aspects and two fundamental questions it boils down to.
1. Is the optional tube amp as a parallel audio (and electrical) path a good idea. It would be unbalanced.
2. Are the Geithain RL 944K1/Basis 11K a good idea, or would you suggest different ones (I know I could just get some with a digital input, but I would like to stay analog here to match the chain)
3&4. I would like to read up on how the PLL + fifo buffers work, aswell as digital sound transfer on a fundamental level (USB vs S/PDIF, etc). I know you cant hear that, its just out of interest. I want to comprehend what happens to the individual sample as it travels that chain.
To me, playing with tubes is a line level thing, best made switchable-bypassed, e.g. Schiit Buf, try different tubes. Or even as DSP/plugin effects.
Digital transports usually either work the same (no "sound" just bits) or they are broken, which is rare these days. Call it bit perfect informally, being strict about it hardly worth chasing.
I know digital transport is not really a concern from a listening perspective. Iam just interested in the technical details, like what dithering and truncation does, how windows multiplies every signal by .99 every time it hands it over to mitigate clipping, how FIR and IIR filters work on a sample/bit level.
The digital hardware I have is for multiple things. I want a hardware controller for the mixing and presets. The RME card lets me use any Midi-CC controller and the Trinnov has its own remote. The femto clock, direct memory access and such are just nice to have. The compatibility of the Trinnov vs the Neumann room correction when it comes to analog monitors, or the fact i have less latency going through the RME, vs a classical WASAPI based mixer, like a Beacn Mix I had befor for overall system latency when I play games or watch a video/stream maybe an argument .
So my questions are more from an understanding standpoint. How upsamling works, R2R vs Delta Sigma and oversampling and such. Not "I need X because the bits are cleaner".
