Need help with compact line array design crossover and box LMS or leap
BC event
Audio Science Review (ASR) Forum
Log in
help/suggestions with design of compact line array Speakers​
BC event
New Member​
Hi guys
I am wanting to build a compact line array with 6.5 inch drivers 8pc 18sound 6nd410, 8pc lavoce WAN 061.80, 6pc lavoce DN 10.172K I have some wave guides, and I have the 18sound drives
please read to the end
1 Im after help with box design
Length of array (was thinking 1.4mt can go upto 1.7mt the width will be 400mm the front pannel will be flat but i can angle the drivers in the box if needed
Box volume?
Port size?length? 25 mm port per drive would work
Driver spacing min 15mm
Driver coupling to get the extra 3db is important
2 Crossover, delay and phase all looked into
Low and mid driver are 8 ohms can pick 16 ohms compression drive if wanted to lake lower sensitivity ( better for d Class amps )no white noise lol
A Setting for 3 way active with time delay for each driver trypes
B Setting for 2 way active and passive crossover
low and mid with passive crossover and high with own channel time delay
low and mid drivers wired with 2 in series to make 16 ohms then paralleled up to make 8 ohms for one crossover
2 mid crossovers/ lpad and 2 low crossovers per box for power handling
High will have active
Box ohms
4ohms low
4ohms mid
6 or 12 ohms high
let me know if you need any more info
any input would be great
i am an electrician by trade
in brisbane
please see drawing for layout
will sit above 4pc 18in subs per side
If you are interested and have the skills,time and computer programs to desgin and model im happy to pay a small fee
Thanks Bart
