Need help with a power adapter for a Jecklin Transdyn 2
Kei
For years I have owned this apparently very rare Jecklin Transdyn 2, that I got together with some other old gear. However, I don’t have an AC-AC adapter for it, so I have never been able to check if it even works.
I know/understand very little about electronics, so I need some help: what do I actually need to buy to get this powered up?
These are the specs from the manual:
So, 220 Volt AC (I live in Sweden, so no problem) to ”2 x 15v” AC, whatever that means… It uses this 3 pins DIN connector, where the orange wire and one of the black ones goes to the power switch -> the fuses -> what I assume is a full bridge rectifier:
I guess the DIN connector could be replaced with some other connector if that would make things easier. Any help here to get this running would be much appreciated!
Any transformer with 2x15VAC secondaries will do,either a ready one or a toroidal that you can put in a box.
You'll need one with center tap,just cut the old connector and connect it straight to it.
I don't think that will work.
I can't be sure, and I'm not I'm not an electronics expert, just a hobbyist, but given that the Jecklyn uses a three pin power connector, I suspect it is connected something like this:
Where the 2 black and the orange wires on the right correspond to those on the 3 pin connector.
Since one of the black wires and the orange wires both go to the power switch and then to the fuses, shouldn’t that be 15 V och each of those two, with the second black wire for 0 V?
The rectifier from both sides, one flipped so things line up.
And an ugly drawing of the components seen from underneath along the traces:
Does all this then mean that 15+15=30 V DC will be going out on the red wire?
Yes, I think this is a very basic, dual rail power supply, along these lines:
In your image above, pin 1 and pin 3 are 15v AC, and pin 2 is the 0v centre tap.
It's odd that they chose to use 2 black and one orange wire, rather than 3 different colours, or choose the orange for 0v, as it's the odd one out. :confused:
In any case, as long a you connect pin 2 to the centre tap of the transformer, or the combined 0v wires of a transformer with dual secondaries, it doesn't really matter which way round you connect the other 2.
Reactions: Kei
I showed my latest image to ChatGPT, and I’m amazed that it understood the whole thing:
So if I would get something like this: https://www.farnell.com/datasheets/3170001.pdf
Then I would connect Red to Pin 1, Yellow to Pin 3 and join Black and Orange (or just one of them?) to Pin 2, correct?
Yes, connect the black and orange wires to effectively create a 0v centre tap, and connect that to pin 2.
The red and yellow wires go to pins 1 and 3. It doesn't matter which goes where, as it's AC.
If you use a metal box, I would use a 3 pin mains inlet and connect the case to earth: https://uk.farnell.com/schurter/6100-3200/inlet-iec-c14-6100-10a/dp/2080464
You can get versions with a fuse and a switch. Fused might not be a bad idea, as I don't think you have a fuse in the mains plug, as we do in the UK:
If you use a plastic box, you could use a 2 pin inlet: https://uk.farnell.com/schurter/6160-0021/inlet-iec-c8-2576-2-5a/dp/2080474
A length of 3A, 3 core mains flex will work for the cable to the 3 pole connector: https://uk.farnell.com/multicomp-pro/ps000052/din-audio-video-conn-plug-3pos/dp/2787092
I'd use a terminal block to connect the 3 wires of the mains flex to the secondary wires of the transformer. You could then just twist together the 2 x 0v transformer wires and fit them in one side of the block: https://uk.farnell.com/hellermanntyton/cs5ntpe/terminal-strip-connector-natural/dp/4166059
I'd use a cable gland, which will grip the cable to the 3 pole connector and prevent it being accidentally pulled out of the terminal block: https://uk.farnell.com/pro-power/pg-11-black/pg11-cable-gland-black/dp/3498412
If you build it, post some pictures and let us know if it works.
If it bursts into flames, post pictures of that too. :)
Haha, will do!
Since I would need some kind of enclosure too, I think I might actually buy this one that I linked above:
And then replace the trafo and PCB with these (but the 50053K, which is 2x15v) and connect an outgoing cable with a 3 pin DIN instead of a socket:
This actually feels doable.
