Need help to get a portable DAC
vvs.angelo
I am thinking of buying a cable for the ER4SR for my birthday and I would like to take a portable DAC that measures well (at processing level since the ER4SR do not need so much power) and I would like to know which options are the most recommendable taking into account these aspects:
-I am an iPhone user
-I usually use the dongles both in PC W10 and with mobile phone.
-If it is possible to have internal battery would not be wrong
-Support a good amount of formats and be compatible with Neutron Player.
You're going to buy a cable for your birthday? So you want the portable DAC to test this cable?
JSmith
No, I want to take advantage of the purchase to add a dac, I'm not from the USA, but you know, CABLES MAKE A DIFFERENCE
