Need help! SmSl a100
Бонжур
Кто поможет понять? Подключаю smsl a100 к стримеру nuprime omnia, динамики ave 700 играет на пол громкости, а затем при увеличение громкости, сгорает усилитель smsl a100, и больше не играет
Please post in English here. Thank you. Welcome Aboard.
“Who will help you understand? I connect the smsl a100 to the nuprime omnia streamer, the ave 700 speakers play at half the volume, and then when the volume increases, the smsl a100 amplifier burns, and no longer plays”
Who will help you understand? I connect the smsl a100 to the nuprime omnia streamer, the ave 700 speakers play at half volume, and then when the volume increases, the smsl a100 amplifier burns out, and no longer plays
AVE-700 4Om, smsl a100 4Om.
AVE EC-700H
This appears to be a home theater speaker setup (front L+R, surrounds + sub). Are trying to drive the complete set of speakers from the smsl a100 ?
if so, you may have to do some combination of series/parallel wiring to keep the total impedance between 4 and 8 ohms.
I checked with a multimeter, the speakers give out: left 2.6ohms right 2.9ohms
Let's assume, after turning off the amplifier-it began to turn on, but does not reproduce the sound! did it burn down?
If the amp is no longer producing sound, it is most likely damaged.
You're showing approximately 2.9 ohms which may be what damaged the amplifier.
How did you have the speakers wired up ? Did you have multiple speakers wired in parallel to each channel ?
The speakers are working! I checked.... I connected them to another amplifier, they work perfectly! The smsl amplifier does not reproduce the sound, which upsets me.... And yes, I connected the speakers by channel, that is, one speaker per channel!
I tried to connect these ave speakers via a bose amplifier, they work fine, but it's just huge, not like smsl)
It seems to me that this smsl a100 model does not have any overload protection, so it burned down, this is of course purely my opinion.... And in general, I would like to repair it, upgrade it and use it in my speaker system.....
It would appear that your Bose amp is capable of driving lower impedance loads than the smsl. Since the Bose has 4 channels, did you wire it differently than with the smsl ?
Yes, I have broken down channel by channel, each speaker!
It would appear that your Bose amp is capable of driving lower impedance loads than the smsl. Since the Bose has 4 channels, did you wire it differently than with the smsl ?Импеданс 4Ом
Looks like the smsl cannot drive multiple speakers wired in parallel. If you end getting it repaired then you will have to wire the speakers in series to avoid this problem.
Спасибо
