Need help, one dac with two headphone amps
1984
I have one dac and two headphone amps. Which is a good way to use 2 headphone amps with one dac rca y splitter or switch box like schiit sys?
Thank you
ernestcarl
There are some cheap unbalanced switch boxes that could add additional cross-talk. I have a bunch which I’ve replaced with pricier balanced switches. The level may be so low as to not really matter in the real world.
twsecrest
California
I have one dac and two headphone amps. Which is a good way to use 2 headphone amps with one dac rca y splitter or switch box like schiit sys? Thank you
Using a RCA y splitter will mean each headphone amplifier only get half the voltage.
Ratatoskr
Sys has two inputs and one output. You need one input and two outputs. Would Nobsound Little Bear work?
raindance
You can use a splitter with no issues, however depending what the input circuitry of the headphone amp looks like, you may need to have both headphone amps powered on to avoid issues from an unpowered input stage. So long as the DAC has a low output impedance, which most do.
RayDunzl
Central Scrutinizer
Riverview FL
ernestcarl
Actually, you only have one source (DAC) running so this probably won’t be likely an issue? I remember when I had two or more DAC sources playing and split to a single amp, the sound of the physically bypassed device via cheap switch could still barely be heard as the non-bypassed DAC is muted.
