staticV3
- Joined
- Aug 29, 2019
- Messages
- 15,051
- Likes
- 26,448
Furthermore, set RTA->Cogwheel->Max overlap to 93.75% for slightly faster data acquisition.
And I'd also disable "Stop at: 45". Personally, I usually do 100-150 AVGes, even 300 at times though that's decidedly overkill.
Regarding the dip in bass response, try replicating your room and speaker placement in the REW Room sim.
If that shows the same dip with both subs active, then that's a solid indicator that the tool is reliable.
Next, try to find sub placements in the Room sim that have no strong dips.
Peaks are ok, those you can cut with PEQ. Dips OTOH you can only fight with room treatment, placement, or fancy DSP like Dirac ART.
