There are after market vesa adapters on Amazon for small genelec monitors. I attached my G one's to a clamped pole.
Nice one!
But my desk is very small so I don't have much space for clamps to hang the speakers.
Have you posted an image of your setup right here? Because you have extremely tight and specific requirements and I think that is the real problem.
The problem to solve are the limiting requirements first instead of trying to fit everything in the very narrow target zone. Is there no way you can put speakers behind your desk? What does anything look like!?
Your alternative is to go with coaxial speakers so you can have them horizontal position as well. And don't forget, it may not be ideal but you can also put two-way speakers upside down and have the tweeter on the bottom. This will also allow you to have them physically higher off the table so the tweeter isn't just reflecting off the desk.
Thanks for reply,
No, I didn't post any image of my setup, will do.
But until then,
All start due to ergonomic problem,
My table is 100cm x 60cm, 72cm height.
On this table I have 2 24" monitors on gas spring arm they alone comes out the width of the table,
As I really love to hear music, and most of day hear, I bought an PreSonus Eris E5 monitors, they connect to DAC (SMSL D6),
Now as I don't really have place on the table, I choose the Eris because I can make them horizontal, after the speakers height (when they horizontal) finish the screen monitors start and their height really high (because the speaker monitors).
So soon I plan to switch the table to lower one, 65cm height (62cm without the top plate) and also want to replace the speakers, first they really big and also high in height.
Sure I prefer that the speakers will be as they need to, vertical but I'm taking in cosider my limitations.
A single 27 should be physically narrower (though taller) than 2 24s, and a lot nicer to work on IMO. I have a 4K 27 at home, and 3 1080 24s at work - I’d take my home setup any day.
I know that 27" will be narrower and it will be great.
I use 2 monitors much time, really love it.
I need it because I developer and like to see in one screen the design (for example), other screen the code.
In 27" 2 full windows (for example 2 full websites) comes in?
You have an 27" maybe you can make a picture how it's shows? 2 full windows of this thread (or other websites as well)
The ideal height for sound quality is usually with tweets at ear level. Speaking from experience it does make some difference.
Yes know that, but didn't love they really high.
The height of the screen monitor is 31cm.
