Right.
W/o tilt base, the D3V is 20cm tall.
If we temporarily assume that the tilt base only tilts and doesn't add any additional height, then we can conclude from the following data:
Height=20cm, Depth=15cm, Tilted Height=24cm
..that the base adds about 20° of tilt, resulting in the front upper edge to rise to 24cm (as stated) and the rear upper edge to drop to 18.7cm height.
Whether that'd fit into your planned desk setup, I don't know.
But then you also need to consider the same thing for all the other speakers. E.g:
- EVE SC203:
Another curious design:
Not sure which config I should assume to interpret the official dimensions, so am not neven gonna try.
If useful, tilt can be set to 0/7/14°
Please keep in mind that for all of these numbers, I assumed that the tilt mechanism would keep the rear bottom edge of the speaker in contact with the desk.
If instead the tilt stand also lifts that edge off the desk, then you need to add this offset to the heights calculated above.
Thanks! wow which a response.
So let's answer,
24cm height is too much for me, because after the speakers the screen monitors start (the screen monitors above them).
Genelec 8010A:
195mm height is with the isopod but w/o tilt, so the Genelecs would be even taller once tilted upward.
You right, they too tall and too pricey for me. Deleted from the list.
iLoud Micro:
180mm is likely with the tilt leg not extended, so with the speaker sitting flat.
Judging from iLoud's diagram, height at the front of the speaker would increase to ~193mm with the leg flipped out:
The iLoud's tilt appears to be less severe btw, just about 10°.
They don't mention in their website the height with the tilt open, but I saw 2 different images,
https://cdn.shortpixel.ai/spai/q_lo...om/storage/2021/08/iLoud-Micro-Dimensions.jpg (
Source)
According to this image they say, with the tilt open it's 18cm height.
https://noaudiophile.com/IK_Multimedia_iLoudMM/IK_Multimedia_IloudMM_Size.jpg (
Source)
But according to this image, it's seems like the tilt make the speaker heigher but not that much, maybe you right and it's something like 19cm.
10° isn't enough?
iLoud Micro Pro:
Same story here. Though no similar diagram exists for the Pro, if we assume identical 10° tilt mechanism as on the regular Micro, the Micro Pro would grow to 221mm tall.
Yes, too much after the tilt. Deleted from the list.
Kanto ORA:
175mm height is yet again with the speaker flat. At 10°, front upper edge would rise to 197mm. At 20°, 213mm.
Here there is a different story,
According to the website, the height is 17.5cm,
Then with the S2 stands of Kanto, the height will increase by 3.4cm to 20.9cm with 16° (
Source)
But I can make them horizontal instead of vertical and save some cm, the question is if the sound much hurt from this.
Kanto YU2:
150mm at 0°, 171mm at 10°, 187mm at 20°
Same as ORA, but I think I can't horizontal them.
With the S2 stands the height will increase to 18.4cm.
Edifier M60:
168mm at 0°, 191mm at 10°, 208mm at 20°
Some Universal Desktop Speaker Stand Metal Bracket from Aliexpress with 16° give increase of 3cm, then the M60 still in the frame.
Edifier S880DB:
Website says 168mm tall, but that's actually the depth, with height being 230mm. It has to be, when you look at product pics taken from the side (
Link)
You right.
I checked with google and they 230mm tall, deleted from list.
Vanatoo Zero+:
The trapezoidal design makes this the only speaker on your list which would actually shrink when setup tilted.
Tilt appears to be ~14° based on Vanatoo's diagram:
Height would therefore go from 190.5 to 183mm.
Nice, both the heights in the frame of what I need.
I would strongly consider the Kali IN-UNF. The "weird form-factor" is pretty much ideal considering your space limitations, and when set up correctly they perform extremely well, better than any of the extremely compact "normal" bookshelf models.
Thanks for reply,
First, their price is something like $947 (Closed to Genelec)
Second, from what I saw the subwoofer need to be on the desk too? I barely have space for speakers, then for subwoofer?
