Good day everyone, first time posting here.
I had been using my speakers on my desk for some time but recently made some diy stands and got a measurement microphone. The goal was to move towards a midfield/farfield setup.
Signal Chain: PC -> Scarlett Solo -> Edifier T5s -> JBL 305p
Listening position was decided by placing the speakers in the corner and playing pink noise, the current position resulted in least nulls.
Subwoofer placement: Took a sweep at every single 12x12 floor tile with the subwoofer at listening positon. 51hz peak is present at every position in the room and only goes away when mic is raised approx 1/4th the height of the room.
Speaker position: Took measurements from 12-36 inches from front wall to the front of the speakers in 6 inch intervals. Took additional measurements 3 inch forwards and backwards from the candidate positions, working with one speaker at a time.
Candidate positions:
12 inch
36 inch
Distance between speakers slightly less than distance between speakers and MLP.
See pics attached.
Measurements:
Attached measurements are an average of 6 sweeps taken 3 inches apart to prevent a knife edge response. Room correction has been applied. 51hz peak was intentionally keep loud because I like the kick it gives in bass heavy music.
Subjective thoughts:
It is not possible to A/B test both speaker distances as it takes me around 2 mins to adjust speaker positions.
Higher clarity was expected at 36 inch due to being more nearfield, however wasn't able to discern any major differences.
Depth of soundstage felt greater at 36 inch due to more space between front wall and speakers but might be placebo effect.
Was expecting bass to be louder at 12inch due to proximity to wall, however due to room correction and a sub results in almost the same bass.
Wider soundstage was expected at 12 inch due to greater distance and louder sidewall reflections, however the whistles and clapping at the start of hotel california live on mtv 1994 seemed equally wide at both positions. The imaging of the whistles was slightly clearer at 36 inch.
Need opinion of people more knowledge than me about this.
Feel free to ask any questions.
Cheers.
12 inch
36 inch
See pics attached.
Measurements:
Cheers.
