Nearfield perspectives
RevTower
I've read some really interesting threads recently about nearfield speaker options, and near field desktop setups. And I've had a slightly different experience then the majority of what I was reading.
I think defining near field in the context of this thread is important. I had an 8ft long countertop set up, with a computer screen in the center. This is where I sat 99% of the time to do my work, because the screen was mounted on the wall, at eye level. My speakers were 3.5 feet from each ear. And they were mounted off the desk with wall mounts, with the tweeters just slightly above the center of my ears. These speakers were towed in to aim at each ear with me seated.
What made a wide and deep down stage was using an older AVR with Audessey. I placed the microphone exactly where the center of my head would be, seated in the chair. Then for the next five positions, I placed the microphone only 6 in to sides of each ear, and then only 6" forward. So the calibration box was basically 6 in to the side of each ear and then 6 in in front. I suppose I may have simply got very lucky, but my sound stage sounded more like I was listening to a bedroom system. The speakers were simple overnight sensations, but of course the Audessey was correcting any frequency response and timing issues. I assume I was able to get away with sitting there and moving around without thinking about staying centered because of the measurement box that was so small around the area of where my head would be at all times. But I never noticed the soundstage or imaging going crazy as long as I sat in that chair in front of the computer screen and did normal desktop activities in front of me.
This was a pleasant and unexpected surprise. I guess I would say to try room correction in your near field set up, but only using a reasonable sized box for your measurement positions. And don't use the standard positioning of the mic, where you move it around the room in different places. I think that's the difference in the results I ended up with, along with the speakers basically toed in and aimed directly at my ears.
Your mileage may vary of course, but I hope this helps someone.
