Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
They do, though I've been a bit wary of shops having local websites but no physical office, warehouse etc.
It gets annoying in the case of warranty, returns, higher shipment costs etc. so I prefer to keep it to local shops where I can go physically in case something happens. I'm not saying Thomann's bad, I'm just not willing to take the chance.
As for Thomann, unless you specifically mean no Romanian office/warehouse, they're one of the biggest european music-related shops (you know I assume), in case you don't consider them trustworthy. But yeah, you'd be looking for ~2weeks back and forth if gear is DOA, etc. I had to mail back a 12" guitar amp to them, so I get that, believe me. Never had any issues w/ customer service though.
Howdy, I am looking to complete my current setup with a 2.0 or 2.1 speaker system (or 2.0 with the prospect of adding a sub later) for my room.
I've been a lurker on this forum for a number of years now, but since I usually found the info I needed in other topics and I didn't feel like I'd add much to any discussion here I didn't even create an account.
I'm no audiophile, however I am a victim of the "placebo" of having the weakest link in the chain being the music itself, so I strive to get at least decent equipment to set the "psychological" baseline. Of course, no snake oil like 10000$ cables or anything of the sorts.
BUDGET and location: 250-300EUR, Romania
Usage: Music
Room specifications(I've attached 2D and 3D plans and a picture of the desk in question):
4.5m x 3m (13.5sqm)
Untreated, but I am planning on doing something mild about it sometime later like some paneling on the walls around the desks, not a priority right now
I will of course look into room correction EQ as well.
Positioning: Flanking the monitor on both sides, on the desk, will employ some foam pads for isolation.
Current/previous source/equipment:
FiiO K11(DS, not R2R) DAP, filter 1
Local 16/44.1 FLAC files ( native or resampled from various sources, own CD rips, bandcamp, Qobuz, Vinyl digitizations etc.)
Edifier R1280T(not in the picture, currently serving another room)
Sennheiser HD 560S(relevant here just because I like their sound both default and EQd to Oratory1990's preset, but lean more towards the EQ for the warmer presentation and low end punch)
Before going into speaker options, I may or may not also "upgrade" the FiiO K11 to something else, mainly for connectivity(looking to have Balanced XLRs in case I go for monitors), integrated PEQ and a more powerful headphone AMP for some reserve power. Was looking at either the K13 ESS or the Topping DX5 II. However, looking at the myriad of issues with the DX5, hardware (which I understand have been fixed by revisions) and software, I'd lean towards FiiO. I'm waiting for measurements of the K13 ESS though, not because I could hear them, but just to validate that there aren't "surprises".
From the research I've done and given my low budget I've landed on these options, prices at the time of writing, though Black Friday is this week here and likely there'll be a few discounts (20-30EUR at most):
Edifier S360 2.1(280EUR)
It looks convenient with the wireless sub, would definitely help with positioning it. From the people owning it I understand it sounds ok for its price.
Adam Audio T5V / T7V / T8V* (175EUR / 225EUR / 290EUR per unit ) + SUB prospect
*I think the T8Vs are way too big and oversized for my room, but I'll mention them nonetheless.
In this category it's between the T5Vs and the T7Vs. I have heard that the T5Vs might be the choice for small rooms with an added sub later if needed.
But I've also heard that T7Vs might suffice alone and I can add a sub to them too should I feel the need, but I likely wouldn't
All of this however is speculation until I have them on desk and listening.
Adam Audio D3V (290EUR)
I have heard really good things about these little rascals, but I feel like they don't fit my needs and I am not constrained by physical desk space so these are just a mention mostly.
Kali LP-6 (2nd wave) (200EUR per unit)
Haven't done much research about these, but they're in the price range and seen some Kalis recommended here and there
From some YT sound demos (yeah, I know) the ones that drew my attention were the ADAM T series. From the bunch, as I've said previously, I'm leaning towards the T7V or the T5V with the prospect of adding a sub later.
Sorry for the long post, hope to hear you guys's opinions, don't refrain from calling me out if I spouted some BS.
I'm using the Adam D3V and it absolutely rocks, If you're sitting 1m or farther away then get the T5V as they get louder otherwise get the D3V. The shorter distance between tweeter and woofer means sound feels natural, the T5V in very close distance feels like the sound is separated between the woofer and tweeter.
Make sure to get a UMIK-1 so you can EQ properly.
I'm currently using a D3V paired with an RSL Speedwoofer 10e. I downgraded from an Ascilab C6B and i dont really miss it at all, once you have a neutral, calibrated speaker system you're good to go. I listen at 80-85 db max, if you want louder sounds, get the T5V. Make sure you have some foam or stands so the desk vibrations dont cause trouble.
Looking at your desk, anything other than a D3V or Kanto ORA/ORA4 would be too big, trust me, I had a T5V and exchanged it for a D3V, so yeah
In the end I decided to go with the MR3 + T5s combo.
The Adams all had good discounts, the T5V and the D3V were well into budget, but I ended up agreeing with Jiraya369 that even the T5V might be a bit too big.
What I hadn't done before in all the tabs I had open for research and other stuff is just relatively measure where they'd fit. Between the speakers themselves at ~30cm depth + cables + the eventual angling.
I pondered whether to get the D3V and the T5s sub, but there was no way to integrate them both without a separate interface so I went for the more robust option.
Thanks everyone for the input and advice!
