Nearfield desktop speaker advice (13.5sqm untreated room, ~250-300EUR budget)
DeLawrence
Howdy, I am looking to complete my current setup with a 2.0 or 2.1 speaker system (or 2.0 with the prospect of adding a sub later) for my room.
I've been a lurker on this forum for a number of years now, but since I usually found the info I needed in other topics and I didn't feel like I'd add much to any discussion here I didn't even create an account.
I'm no audiophile, however I am a victim of the "placebo" of having the weakest link in the chain being the music itself, so I strive to get at least decent equipment to set the "psychological" baseline. Of course, no snake oil like 10000$ cables or anything of the sorts.
BUDGET and location: 250-300EUR, Romania
Usage: Music
Room specifications
(I've attached 2D and 3D plans and a picture of the desk in question):
  • 4.5m x 3m (13.5sqm)
  • Untreated, but I am planning on doing something mild about it sometime later like some paneling on the walls around the desks, not a priority right now
  • I will of course look into room correction EQ as well.
Positioning: Flanking the monitor on both sides, on the desk, will employ some foam pads for isolation.
Current/previous source/equipment
  • FiiO K11(DS, not R2R) DAP, filter 1
  • Local 16/44.1 FLAC files ( native or resampled from various sources, own CD rips, bandcamp, Qobuz, Vinyl digitizations etc.)
  • Edifier R1280T(not in the picture, currently serving another room)
  • Sennheiser HD 560S(relevant here just because I like their sound both default and EQd to Oratory1990's preset, but lean more towards the EQ for the warmer presentation and low end punch)
Before going into speaker options, I may or may not also "upgrade" the FiiO K11 to something else, mainly for connectivity(looking to have Balanced XLRs in case I go for monitors), integrated PEQ and a more powerful headphone AMP for some reserve power. Was looking at either the K13 ESS or the Topping DX5 II. However, looking at the myriad of issues with the DX5, hardware (which I understand have been fixed by revisions) and software, I'd lean towards FiiO. I'm waiting for measurements of the K13 ESS though, not because I could hear them, but just to validate that there aren't "surprises".
From the research I've done and given my low budget I've landed on these options, prices at the time of writing, though Black Friday is this week here and likely there'll be a few discounts (20-30EUR at most):
  • Edifier S360 2.1(280EUR)
    It looks convenient with the wireless sub, would definitely help with positioning it. From the people owning it I understand it sounds ok for its price.
  • Adam Audio T5V / T7V / T8V* (175EUR / 225EUR / 290EUR per unit ) + SUB prospect
    *I think the T8Vs are way too big and oversized for my room, but I'll mention them nonetheless.
    In this category it's between the T5Vs and the T7Vs. I have heard that the T5Vs might be the choice for small rooms with an added sub later if needed.
    But I've also heard that T7Vs might suffice alone and I can add a sub to them too should I feel the need, but I likely wouldn't
    All of this however is speculation until I have them on desk and listening.
  • Adam Audio D3V (290EUR)
    I have heard really good things about these little rascals, but I feel like they don't fit my needs and I am not constrained by physical desk space so these are just a mention mostly.
  • Kali LP-6 (2nd wave) (200EUR per unit)
    Haven't done much research about these, but they're in the price range and seen some Kalis recommended here and there
From some YT sound demos (yeah, I know) the ones that drew my attention were the ADAM T series. From the bunch, as I've said previously, I'm leaning towards the T7V or the T5V with the prospect of adding a sub later.
Sorry for the long post, hope to hear you guys's opinions, don't refrain from calling me out if I spouted some BS.
Hello and welcome to ASR.:)
Why wouldn't they suit your needs?
You mentioned the Edifier S360 2.1 speaker/subwoofer combo. Then there’s also this option::)
In your price range, the Adam Audio T5V / T7V / T8V* (175 EUR / 225 EUR / 290 EUR) — potentially paired with a subwoofer — and the Kali LP-6 are also good alternatives. :)
Are the T8Vs too big for your room? It’ll work. I have dual 12-inch subwoofers in a room of your size ( bit larger, but not by much). It works perfectly fine, after some tinkering with their placement, plus some EQ to address the nasty room modes in that space.
I’m actually considering downsizing, but that’s out of consideration for the neighbors—I can’t really utilize the subwoofer’s full potential.
BUT it can make sense to have smaller speakers—which thus act more like point sources—compared to larger ones. Especially the more near-field listening, the shorter the listening distance, it becomes.
I will second the idea of the Edifier MR3's. I have a pair and shared my set up with measurements and EQ with this ASR post:
Thanks for the replies so far, I'll try to clear some of the aspects.
I went off of the assumption that the D3V's main selling point is the compact form of which I don't really have a need of. I picked them up on my radar solely because people praise them for what they are, small and powerful sounding. However, they're still at the top end of my budget and I have a feeling I might want a bit more low end. Of course, as I've established, that can come later, should the need arise.
Naturally, I could be speaking BS and those little things would probably rock the room around(figuratively speaking), but alas, that's the unfortunate part of audio, when I can't test the things myself.
Yeah, as I mentioned under the S360, the idea of an out of the box wireless sub is convenient for placement and setting. I have looked for the MR3 + T5s combo and I actually found both at a reputable shop for 200EUR (90EUR for the MR3 + 110EUR for the T5s). Quite frankly... this looks good, really good, and since the T5s is more compact I've just the spot for it on the right side under the desk. I've looked through the review and topics and I'm hearing nothing but good things.
And frankly I expect that. The R1280Ts I had before, I bought on a whim like 5 or 6 years ago at about 50EUR...I thought wait, why are they so cheap? I was using a Logitech Z533 back then(don't judge) which was more expensive than the 1280s. The 1280Ts kept blowing me away so I kept using them.
The low end wasn't there, and I wanted some more of it, but that wasn't the speakers' fault. I got exactly what was advertised. I just never got around to adding a sub to them.
None of them jump out though, having any hidden quirks or advantages over one another?
I see, so as long as I'd properly set them up afterwards, size wouldn't matter(that much). Thankfully, no neighbors to piss off for me.
That's the primary goal, I'm not looking to throw parties with this setup. (That setup comes later. :))
The more I look around the more attractive the combo between the MR3s and T5s becomes.
I assume since they're smaller and more "directional"(am I using the term right?) or focused should I say?
If I decide to go with this setup, should I look into some stands or pads to angle/raise them at ear level?
Would a simple angle desk stand suffice, or should I look into something to raise the entire bodies up?
Also, how would one go about connecting and volume matching them? I assume, since the MR3s lack a sub-out, it'd look like
OUT the K11> IN T5s and Out T5s > IN MR3.
In this case, I guess the volume would be controlled by the K11 which would be a bit odd since the MR3's knob doubles as an ON/OFF button too so that'd mean I'd "lose" the volume setting when turning them off. Am I mistaken?
I assume since they're smaller and more "directional"(am I using the term right) I should look into some stands or pads to angle/raise them at ear level?
I prefer separate stands that are adjustable so the tweeter is at ear level, wedges are good if your chair never moves...
The best way would be with a 4ch DAC like MOTU M4 or similar so that you could EQ the sub channel if necessary, this was my plan utilizing my Scarlett 6i6 but it sounds good good enough right now with an RCA splitter for the MR3s and sub so I haven't revisited.
The MR3s have a sleep function, they'll turn themselves off after not getting a signal. I just leave mine on and haven't touched the volume knob since setting them up.
I see, well, researching continues, but so far from the info gathered, the priority looks like this:
  1. Edifier MR3 + T5s
  2. Adam Audio T5V/T7V (I still think the T8Vs are quite big for my room and they may require more fiddling for which I may not have the gear/patience for, but if the offer's good, I'll get those) + sub (later or I could probably fit the T5V + T5s sub with a bit of luck)
  3. Kali LP6 V2 + sub (later)
  4. Adam Audio D3V
It'll probably all come down to price/discounts friday.That isn't to say I'll get the cheapest, but I'll weigh how deep the discounts go compared to what I'm presumably getting. Audio usually has some genuinely good offers here for BF.
I'll post back once I make the decision and maybe present the setup once it's done and I start fiddling with it.
In the meantime, anyone who has any more advice, feel free to chime in, and thank you once again for the quick and prompt responses.
P.S. Sorry if I ramble too much.
Double check the price on the Kali, I am guessing that is the price for one speaker and not a pair.
I recently bought the Edifier MR4 Mk II for my kids playroom. They sound quite good for the price and addition of bluetooth makes for a good connection option.
Double-check whether the Kali price is per speaker or per pair.
For the MR3 + T5s, I’d split the K11’s variable RCA output to both rather than assume the sub output is a transparent pass-through. Set the speaker and sub levels once, then control volume from the K11.
Small adjustable stands are ideal, but wedges are fine if your listening height stays fixed.
Yeah, all the monitor prices are for one unit. I guess in all the rambling I forgot to write in the parentheses if the price is for one unit or the system. I've edited the main post to reflect that.
That's why I'm waiting to see what gets discounted friday and how heavily as the offers are good on the audio side as I've previously mentioned. Pairs should all reach the neighborhood of my budget (the T7V and T8V might go a bit over, but again, if the offer's good enough I might stretch the budget).
Generally speaking—and this probably comes as no surprise—the larger the speaker, the more bass it produces. If the largest models you’re considering provide enough bass for your needs, you can avoid the hassle of adding a subwoofer. Integrating a subwoofer with speakers effectively can be a bit tricky. On the other hand, if you enjoy that kind of tinkering, the MR3 + T5s make for a really great combination—especially considering the price. At that price point, I highly doubt you could find anything better.:)
What else is there to say? Speakers differ in terms of dispersion. It’s really a matter of personal preference—whether you want a wide soundstage or a narrower, more focused presentation. It’s something worth thinking about.
I imagine that preference forms after listening to various units and signatures though and since I haven't had that many encounters with proper audio equipment apart from headphones and a few lower budget offerings, I may actually not know what I like most yet.
Given I've enjoyed and still enjoy the 560S as a headphone I guess my preference lies in the middle to maybe towards a wide soundstage.
Soundstage on these is relatively wide, but not to the point where I don't know what's where. Of course, speakers are a different matter, there more variables involved.
I guess me finally trying to get something more expensive thinking it's "better" could also be a case of not knowing what's "good enough". But that's a lesson that I'll learn once I play around with more equipment. I know this hobby gets expensive fast and often times the jump in price is not proportional to the jump in quality (if there's one at all).
I said I'm not enticed by "snake oil" products, but I won't say I'm immune either. And if I'll make some mistakes, so be it. I just hope I'll have the character to recognize that and joke about it instead of doubling down like "no no guys, it's a difference, trust".
It also depends on the room's acoustics, but you can experiment and try things out. You mentioned this in your initial post.:)
A few tips regarding this:
Do you have these kinds of acoustic panels in Romania?
In Sweden, they have become very popular—not just for their acoustic properties, but largely for their appearance and the fact that they are inexpensive. I’m skeptical about how much sound they actually absorb, given that the fabric is so thin. It would likely be more effective to place some 5-centimeter-thick foam (or mattress-like material) against the wall and then mount the panels on top of that.
Here is some visual inspiration:
Large windows? A thick curtain can help dampen the reflections.
Ask a friend to move a mirror along the walls while you sit in your listening position to identify where the first reflection occurs. Try adding some absorption at that spot. You might find the sound gets better... or maybe not. Just give it a try.:)
Place a large, thick rug in front of the speakers. That, combined with a decent amount of furniture, is usually sufficient in most cases.:)
Not too much damping, though; otherwise, the sound becomes too dry, dull, and lifeless.
View attachment 569141View attachment 569142
As a matter of fact I have found those exact panels a few months ago when I was walking around a big shop and put them on the "keeping an eye on" list.
I was and still am skeptical on how much sound they can dampen, but since they are also quite inexpensive, one should temper their expectations. They can definitely be better than nothing.
As for the curtains and other means of "ghetto treating" the room, I have "ideas" that do not involve turning the room into a foam cave.
Thanks for the tips though. Much appreciated.
As much as I love the Edifier MR series, they should not be in the same discussion as the Kali. The Kali are generally among the best regarded well priced professional studio monitors out there. Not at the level of Genelec but they are a fraction of the Genelec price too.
If you can afford the Kali then they are the best choice from your list.
Those thin acoustic panels only help with high frequencies. Going by their thickness maybe 5khz and above. To get something that goes to about crossover frequency of a sub you would need something a lot thicker at least 100mm (~4 inches) thick.
Yeah, they’re good overall; the only thing—considering the price—that I think should be better is the distortion level. For instance, there’s twice as much distortion in the
Kali LP-6v2 compared to the super-budget Micca MB42X G2.
Oh, they definitely do not belong in the same discussion, although jury's out if I could perceive just how much better they are.
It'll all come down to prices, though in being advised towards the MR3 + T5s combo I've realized that I may have "jumped the gun" thinking of going for professional monitors from the get go, especially since the main focus is listening, not production.
I suspect that's why you guys are swaying me towards the budget consumer options I've listed/adjacent to them. Also, further reflection made me realize that that package gives me the best coverage of the entire spectrum so it might also be the smart choice to start off, rather than dump all the budget into monitors and then ending up wanting a sub anyway, which could prompt the need for a new interface and so on.
It's quite possible that I don't understand all the variables fully, especially since previous setups were basically put them on the desk and blast with little to no regard for positioning, room acoustics, desk isolation etc. So if I don't improve that along the way, it won't matter how good the setup is objectively I'd reckon.
But at the same time it's a hobby that I'm quite excited to get deeper into, and starting from more humble beginnings might not be the worst thing.
Let's wait for mkIII reviews.
Out of Budget. (About €400-500 per pair).
Professional JBLs aren't available in my country, at least not from shops I trust. There are some offers from import, but that's about it.
