Hi everyone,
I’m currently measuring loudspeaker drivers in an anechoic chamber and I’ve run into a couple of doubts.
First, regarding the boundary between near-field and far-field: I haven’t been able to determine which criterion is the correct one. Some sources define it as a^2 / \lambda, while others use 2D^2 / \lambda. I’ve checked two different books and they seem to contradict each other. Could someone clarify which expression is appropriate, or in what context each one should be used?
Second, I’m working with both a tweeter and a woofer, and I’ve measured their impedance and frequency response. I’m using the impedance measurements to extract Thiele–Small parameters. However, after measuring the tweeter, I’m not sure whether it actually makes sense to calculate Thiele–Small parameters for it, since these are typically more relevant at low frequencies.
Within the impedance measurement, I also tried applying the added-mass method. However, for the tweeter this required an extremely small added mass in order to shift the resonance peak above its natural resonance frequency, which made the process quite impractical.
Does it make sense to extract Thiele–Small parameters for a tweeter, or should this generally be avoided? And is there a better approach in this case?
