I got a couple of old empty transmission line speakers* boxes for free (no one wanted to buy them so the seller gave them away, thanks for that)
I have a couple of low power 8 inch vintage bass drivers, with pitiful small magnets, probably pretty high Fs and so on that were suitable to mount directly in the TL boxes. Tweeter, the subject of this thread, ND25FW-4 I mounted in them. They also fit directly in the TL boxes.
I use an active crossover for this test. Crossover point set to 2.6 kHz (24 db L-R filter). It fits with the C-C distance bass - tweeter. Plus you probably shouldn't push the ND25FW-4 tweeter lower down in frequency then that.
It sounds nice , or ok, I must say. The tweeter, despite not being flush mounted, is good. The tweeter is the best thing about the TL boxes at the moment.
The 8 inch bass driver, well.Midrange ok. It doesn't work low down in the bass frequency. Hopefully it was a trade off for better/smoother FR higher up in frequency. Fairly high sensitivity is a plus though and it doesn't seem to have any nasty break ups. Bass output about like a medium to smaller "standard" ported speaker with 6.5 inch bass driver. Which of course, considering such large boxes, is not acceptable. A waste of space, so to speak.
Another challenge with TM boxes is to dampen them with just the right amount of stuffing. A lot of stuffing can be needed, which reduces their effectiveness. A topic for another thread.
By the way. Here's a picture of the Infinity bass driver next to a Seas 21 REX DD 8 inch bass driver (it didn't fit in the TL boxes, need to saw the mounting hole then... which I might do). You get what the lack of bass output is due to:
The ND25FW-4 tweeter will be popped into the ones mentioned in #33. This was just a test. Both of the tweeter, the crappy bass driver and the TL boxes.By the way, that Infinity bass driver in the sealed original speaker boxes, model Infinity 1500e, with subwoofer is a much better solution.:
....But I like the ND25FW-4 tweeter.
*Or if it can be considered a Voigt pipe/ Tapered quarter-wave pipe (TQWP) because it is built this way. This is what they look like. Another DIY built such speakers:
