NCORE MP Build using Ghentaudio Kit.
decoRyder
Just thought I'd post this in case anyone is wondering how hard or easy it is to build an NCORE amp using a pre-made kit. I used the Ghentaudio NCORE 122/252 MP kit, and using the kit it was really easy to put together the amp. I discarded the XLR inputs, and used the grounded RCA setup recommended by Bruno Putzeys for those of us who prefer RCA.
The kit from Ghentaudio was very, very well made and a real pleasure to work with, I can't recommend it highly enough.
Matias
São Paulo, Brazil
Nice. But why not use XLRs?
decoRyder
decoRyder
I have really good RCA cables, and I really don't want to have to obsess about 'what's the best RCA->XLR' cable - that's just another 'adventure' I don't need in my life right now : )
The grounded RCA setup recommended by Bruno Putzeys will work exactly the same as XLR - in my specific setup - but without actually having to use XLR.
Given the fact that the main benefit of balanced cables is their ability to transfer sound signals over much longer runs/distances without signal loss or interference, and given the fact that all my high-quality RCA interconnects are shielded AND < 1m in length, I remain unconvinced that XLR is necessary for my setup.
YMMV : )
decoRyder
decoRyder
So what was the cost, all up, of everything?
$ 215.00 - NCORE 122MP Module
$ 130.00 - GHENTAUDIO DIY Stereo Case-kit for Hypex NC122MP/NC252MP
$ 6.99 - Parts Express Chassis Mount RCA Jack Pair
$ 351.99
decoRyder
decoRyder
I like your implementation. I guess you have scratched the paint a little so that there is a good mass contact. I comment for others readers (novice in DIY) to consider.
Right I filed off the anodized coating on the inside of the amp - where it makes contact with the shield/audio ground - to have proper mass contact. For the RCA jacks I used recessed mounting flanges, which fit exactly into the pre-drilled XLR cutouts - they simply screw in, perfect fit.
I also applied thermal paste to the metal base of the amp module, which really helps keeping the module cool under load.
decoRyder
decoRyder
Good idea. I have the same thought if I finally buy the future? PURIFI 1ET400A kit.
Yes, I would buy a PURIFI 1ET400A - or PURIFI anything for that matter - in a heartbeat : )
So far I haven't seen them released for sale to the general public though, only OEM.
Julf
Amsterdam, The Netherlands
I have really good RCA cables, and I really don't want to have to obsess about 'what's the best RCA->XLR' cable:)
Are you sure you are in the right forum? So much for the "Science" part...
The grounded RCA setup recommended by Bruno Putzeys will work exactly the same as XLR, but without having to use XLR.
No, it won't work exactly the same. It will work, and Bruno labels it "acceptable", but it is not as good as a fully balanced connection.
Matias
São Paulo, Brazil
Matias
São Paulo, Brazil
Do these contain exactly the same module? Did OP source his from one of these?
Yes, both the Audiophonics PA-S125NC and the Hypex Fusion FA122 use the exact same module, Hypex Ncore NC122MP, as the OP build.
Buddelpudding
So, if I wanted to replicate the build presented in this thread, I would have to extract the module(s) from one of these sources, or is there a way to buy them individually somewhere else? Because to me it would then seem weird for Ghent to offer these kits, if the key parts are only barely available...
Matias
São Paulo, Brazil
They appear sometimes on eBay, but they are not regularly there as far as I know.
Another good reason to go for the Audiophonics. :)
Matias
São Paulo, Brazil
