NCORE MP Build using Ghentaudio Kit.
Koeitje
Is that really the way people DIY this stuff? Seems like a waste of all the nice connections.
Matias
São Paulo, Brazil
Blame them for not selling the modules to DIY market directly...
mika91
Yes, I don't need a trigger, I'm searching a way to avoid pops and clicks so, if You have tried a logic that sequences mute-power on-mute-power off without success, the only way I know is to add a speaker protection circuit that disconnects speakers before power off and reconnects it after power on. The only thing that makes me puzzled is the declaration of Rouge audio and Kjfaudio of pop free power on and off with the control logic.
I built my nc122mp with ghent audio case last week, and I planned to add a 12V trigger to use standby feature and avoid pop/click on power off.
So it seems that even with mute/standby behavior the pop remains ?
EDIT: is using an audio speaker protection kit an acceptable solution (= no sound degradation)?
Something like this, with quality omron relay ?
Not sure how to get AC12-18V to power the module...
Maybe this one, with 220V input ?
Or add this speaker protection in an external case?
sfabio
Italy
The only solution is to let the amp main spms always on ?
I think that if Red_Baron have tried to sequence mute-power on-mute-power off without results, its better to buy an antibump circuit like this
mika91
Ok, if it has no sound quality impact, it should be the way to go.
Not sure how to integrate it however (inside the amp? in an external case?)
mika91
I confirm.
I made some tests this morning, and use standby mode don't resolve the "plop" sound.
If the preamp is on, the plop is quieter than if the pream if off. But stills plop
Very disappointed
sfabio
Italy
I confirm.
Very disappointed
Have You tried with a circuit that correctly implements startup sequence or simply with switches on standby and mute pins? I've no time to test these days :(
mika91
Only manual switch on standby pin J6.3 to J6.9
I don't have the material nor the knowledge to test a startup sequence. ^^
mika91
Maybe I could test a startup sequence with an Arduino board, but don't have one
mika91
According to this ncore amplifier specifications, it has a microcontroller, "Muted start-up process for pop free operation" and "DC detection and protection".
So a startup sequence with combination of mute and standby pins should work
Matias
São Paulo, Brazil
Maybe the DC on the mains is causing the pop?
Julf
Amsterdam, The Netherlands
mika91
Inputs open, or shorted?
I think I tried with and without XLR wires plugged. (will do the test again later)
I hope that was what you mean by "open or shorted"
Julf
I think I tried with and without XLR wiree plugged. (will do the test again later)
By "shorted" I actually mean exactly that - the inverting and non-inverting input connected to each other.
Matias
São Paulo, Brazil
no preamp plugged to the ncore => "pop" on both power on/off
Ok, but I meant DC on the mains. You can test with a multimeter between phase and neutral and check. Maybe this is causing the shutdown pop.
Julf
Not sure how mains DC would cause a pop - the power supply should eliminate the DC.
mika91
ok, so I did some tests again with the amplifier:
- no XLR cables plugged, internal XLR input connector unplugged -> pop on power off
- no XLR cables plugged, internal XLR connector plugged -> pop on power off
- XLR cables plugged only (no preamp) ->pop on power off
- XLR plugged + pream standby ->pop on power off , sometimes on power on
- XLR plugged + preamp on + no active source -> pop on power off
- XLR plugged + preamp on + active source-> pop on power off
So whatever the configuration, I still have the "pop" on power off.
It could be quiet or louder, not always the same sound level (true for all configurations)
Tried to plug AC on different outlets, same result.
Multi-meter gives me around -10mV DC on the AC mains, not sure it's relevant.
Matias
São Paulo, Brazil
Yes, DC is low enough. Seems like it is something the boards indeed.
Just leave them always on. Problem solved. :)
