I feel like there might be a lot to learn here, but it is getting buried in some weird D***-measuring contest.
Your work on this is fascinating. It may also be a turning point in identifying what measurements are sufficient when testing power amplifiers. Thank you.
True. Much more than anticipated. I stick around to get some answers and learn something and because I find it interesting that we do science but not quite.. and IMO not with quite enough curiosity on some topics. There's can be an aura of "we know all that needed be known".I feel like there might be a lot to learn here, but it is getting buried in some weird D***-measuring contest.
I'll continue looking down at the ground and drooling. And retain my belief that stuff that's audible shows up in the audibility range.It is the opposite than @SIY is saying. RF susceptibility, input stage rectification, demodulation very often directly translate to audio. 20Hz - 20kHz view is short-eyed. Unfortunately, this is not a forum with many knowledgeable and experienced circuit designers.
It was not.Stability testing of an amplifier is hardly a parlor trick, if that's what you're implying.
What do the * refer to?...this thread was instrumental in me changing an order from a Hypex NCx500 based amp to a Purifie 1ET4070SA based one...China are getting it...
...I am not giving up on D class just yet...it is the future...the future is now...
Hypex NCx500 specs:
- 700w @ 2ohm
- 700w @ 4ohm
- 380w @ 8ohm
Purifi 1ET7040SA specs:
- 950w @ 2ohm*
- 500w @ 4ohm*
- 250w @ 8ohm*
This seems unwieldy. Instead I would suggest looking at the impedance plot of a couple of hundred moving coil speakers and perhaps a dozen e stats. It may well be possible to sort them into 3 bins:easy, moderately difficult, and ball busters. Then average elements of each bin. Shouldn't take too long to cycle through the 3 dynamic dummy loads. I'm not sure one would need to show all graphs for all three. Instead focus on typical use case with detailed msmts like those used here and perhaps spot checks of distortion and FR of difficult loads. I thinks its safe to say easy loads would reflect even better msmts. Finally for amplifiers whose cost and performance suggest it might be chosen to drive e-stats, then a fourth load would be tested. Thankfully all the FR ribbons are mostly resistive and apart from the notoriously difficult to drive Apogee Scintillas, dong drop to one ohm!An automated version of Amir's cube with say,1000 most populars speaker's parameters (of various types) taken from their measurements and all that in a sequence would be too much to dream on?
I don't care looking like a fool though as long as I gather some new knowledge here and there..![]()
12, if anyone is interestedI feel like there might be a lot to learn here, but it is getting buried in some weird D***-measuring contest.
Is that Celsius or Fahrenheit?12, if anyone is interested![]()
- 950w @ 2ohm*
- 500w @ 4ohm*
- 250w @ 8ohm*
*Full power output now achieved with new SMPS*
Just to clarify to those that my 7040 amps can reach full power (whereas others who use the standard Hypex SMPS cannot)
*Full power output now achieved with new SMPS*What do the * refer to?
Inches or cm is probably a far more pertinent question.Is that Celsius or Fahrenheit?
It seems that something went wrong with your analysis. If one takes your most extreme example, Pan Sonic-Suhteellinen, the sound pressure spectrum for the entire track looks like this:I read somewhere in the thread that there's not much energy above 10Khz and I agree but that's not always the case and since we're talking about extremes in this tread here's a couple (REW's WAV analysis of the actual tracks,NOT acoustic measurement,forget the shown levels):
I just put the WAVs in the REW's WAV analyzer,that's all.[off-topic]
... and if you consider only the last extreme four minutes still like this:
If we ignore the extreme low end SPL around 20Hz, then the high end around 10kHz is still about -15dB lowered compared to the bass range (100-200Hz) - which is significant.
Of course, this is less sound pressure level drop than pink noise (-10dB per decade) and significantly less than average music - but even this extreme music is still far away from white noise (what your analyses of the song is indicating).
"Normal" music vs pink noise spectrum:
I have 5 channels of Purifi and 2 channels of NC252MP, 2 IcePower monoblocs, a Topping PA5 and maybe others I can't recall at this time but I have had zero issues either sonically or w/ reliability with any of them. I couldn't be happier with any of the Purifi or 252 amps but the Icepower monoblocs (of which one was measured by @amirm) do sound harsh at high volumes-none of the other class D amps I have exhibit this type of audible distortion and to my ears are faultless, even at very high volumes.I know this continued discussion is frustrating for some. Especially given the brilliant and essentially "free to me" work from @amirm and others who have the equipment and patience to run tests on real world products without any reward from advertisers and manufactures. In my experience of HiFi I've never been so blessed with excellent information and guidance.
I have a mental model of a Class D (which is not the same as the classic block diagrams) of a black box that provides gain in the audio frequency bands superimposed with an RF device producing Radio Frequency signals which cannot be played by our speakers and which we cannot hear and which is mostly blocked from reaching our speakers by the output filter.
What this thread seems to be about is - perturbations to the RF amplifier - 1) whether a real world device can cause an interaction and 2) whether such an interaction perturbs the RF device, 3) how would we sensibly test and present this.
What is perhaps relevant is how many people are really satisfied with their Class D amps in the real world. Obviously, the vast majority of purchasers can not measure how well the amp works, but if there are real world perturbations to the RF device that folds artefacts such as noise and distortion back into the audio bands, we're not encountering complaints...
