4. about sensitivity, it should be 87db@1000Hz, and I had asked the question to test engineer: why the sensitivity on your report seen lower than my other anechoic chambers? He answer me because he just test another big loudspeaker and not move the mic and platform,so the distance was more than 1 meter. so, I give it.
Amir's measurement also shows that the speaker is very close to 87dB at 1kHz - see green circle below.
Unfortunately, the sensitivity of a loudspeaker is not determined according to a standardized procedure. But the sound pressure level at 1kHz, is obviously not suitable to provide a realistic value.
More realistic is the average value of a certain frequency range - for example from 40-1000Hz or 300-3000Hz,...
The calculation as used by ASR flatters bass-weak speakers with a high sensitivity.
Sensitivity: 83.9 dB (300Hz-3kHz; spec: 87db)
Therefore, the 83.9dB is already, IMHO, rather questionable and 87dB goes very strongly in the direction of a "fantasy number"
Personally, I would rather determine the sensitivity of a loudspeaker as an average value over the range 40-500Hz, since the low and mid range determines how the sound is perceived - which this review has shown. This would put the NS17 at 82-83dB sensitivity. But this kind of calculation would probably cause depression in a lot of loudspeaker owners, because of their "weak" loudspeakers
Honest I am a little shocked when I see the FR of NS17, it looks strange. the peak is more higher and ravine is lower, not more, only 1-2db, but it seen different.
If we look at your own measurements compared to Amir's measurements and make the scaling of the graphs comparable, then the difference is not very big.
If your website shows the measurements of the "golden sample" and then one include driver and production tolerances, then I don't see any contradiction there at all. In fact, Amir's measurement shows that your speaker has significantly more bass than your own measurement shows.
UPDATE: Or was the BR port sealed in your measurement?
The NS17 measurements of
Natural Sound and Amir superimposed:
