reluctant_engineer
- Joined
- Nov 29, 2017
- Messages
- 4
- Likes
- 19
Interesting. I think Tyll's measurement of HP50 vary from yours. QC issues perhaps?
Yikes...you had an account for 1133 days before posting?Interesting. I think Tyll's measurement of HP50 vary from yours. QC issues perhaps?
Give this man an award!
As soon as I saw the above, I picked up my 6 years old pair and took this photo:....
Notice how the two cups are hanging differently from each other. This is because the headband is not symmetrical.
Hard to say. His graph has 70 dB scale which flattens the response. And he is using a HATS for which there is no researched target response. If there were one, it would look different than mine so you can't use the raw measurement from his, and apply it to mine. Only compensated ones can be compared and even then, it is tricky business.Interesting. I think Tyll's measurement of HP50 vary from yours. QC issues perhaps?
Hi amirm, but I noticed that tyll’s measurements are overlain on his own hd650 measurement and except the bass the align very well, whereas your sample showed noticeable drop in mid range compared to your hd650 measurement, so maybe that comparison makes some sense?Hard to say. His graph has 70 dB scale which flattens the response. And he is using a HATS for which there is no researched target response. If there were one, it would look different than mine so you can't use the raw measurement from his, and apply it to mine. Only compensated ones can be compared and even then, it is tricky business.
This alone is very prohibitive to recommend the headphone at all, no sound can justify that a lot of ppl will get a unit which don't even let them listen comfortably, it's like selling you a house where the bed is made out of hard rockMy pair of these don't fit my head at all: they sag down on my ears which is uncomfortable and noticeably affects the FR. The ergonomic shortcomings are really disappointing as I had high hopes for them.
I'm wondering if the problematic fit of these headphones is to blame for the all the differences in measurement and subjective impressions. It's fine if you get them just right but there is little leeway outside of that.
I thought this phone was one of the first to be designed with the Harman headphone research in mind. Or am I mis-remembering that? I thought they were almost like the PSB M4u phones.
NAD Viso HP50 APO EQ 96000Hz
January062021-145603
Preamp: -3.6 dB
Filter 1: ON PK Fc 60 Hz Gain 3 dB Q 1.9
Filter 2: ON PK Fc 200 Hz Gain -7 dB Q 0.91
Filter 3: ON PK Fc 602 Hz Gain -3.67 dB Q 2
Filter 4: ON PK Fc 2370 Hz Gain 3.5 dB Q 3
Filter 5: ON PK Fc 3733 Hz Gain 3.58 dB Q 3.5
Filter 6: ON PK Fc 5550 Hz Gain -5.82 dB Q 4.24
Filter 7: ON PK Fc 7105 Hz Gain 1 dB Q 5
Filter 8: ON PK Fc 10000 Hz Gain 3 dB Q 4
Ah, didn't notice that. Agree that he is showing far less differential than I am. Maybe they did change drivers since then. Or maybe these were rejected because they were out of spec or something. Without having the same sample as what others have tested, it is very hard to troubleshoot such things.As for the measurements, I wholeheartedly agree that measurements taken from different system should not be compared. So that's precisely the reason I used HD650 as a comparison in Tyll's measurement I shared.
LOL, be happy if you can hear a thing at your age.
This I think is what makes headphone measurements so all over the place for so long... vastly different from one rig to another compared to an open room calibrated mic.. and seems sealing is so vital yet difficult to kept consistent among different samples or rigs it makes the equation even more complicated.Ah, didn't notice that. Agree that he is showing far less differential than I am. Maybe they did change drivers since then. Or maybe these were rejected because they were out of spec or something. Without having the same sample as what others have tested, it is very hard to troubleshoot such things.
