NAD PP 4 Review (Digital Phono Stage)
I had one of these and it became distorted and produced weird, crumbly sound after a few years. Online reports of similar problems abound. So even if they did everything right, you can skip this one just because of reliability.
The aesthetics of the unit are terrible—buttons, knobs, plugs, and lights all over the place. At the very least, they should be lined up on the same plane. The record level knob looks like it was randomly placed as an afterthought—which it probably was.
The selector switches should have been another type. Or why not on the front so you don't have to go dig your finger between all your cables when it's already connected?
Thanks.
Side note: does the red bar look taller to you all than the green one to the left of it with the same height? It does to me.
Yes. Was wondering why it was to the right of the one on the left before zooming in on my phone and reading this from you.
Thanks Amir. I hope my NAD PP2 is better than this. At the price point, you'd be better off with an Art DJ and a Focusrite Scarlett 2i2. seems Parks Puffin reigns in the phono pre with ADC category.
If you want the absolute best, a Metric Halo LIO-8 with mic modules or a ULN-8, with a MIO console for the RIAA equalization will probably get your there. For those who like a tube sound you can add the +DSP software and alter the sound to your hearts content. It is way overkill, but one also gains the benefit of 8 excellent DAC & ADC channels, digital x-over and DSP, and it is still much cheaper than "high end" phono preamps...yea, but still overkill... it has a remote :)
In fairness, I should point out that a Metric Halo solution would require them to modify the mic inputs for those who are not comfortable making the necessary changes themselves.
It must a version of this famous illusion:
But I can't find any specific references to it manifesting that way.
The red bar both breaks the pattern of the green bars sloping down and it has a warning color causing it to stand out.
I wonder if the red bar would still appear longer if the green bar to the right was not there at all?
Why rely on subjectivity when you can measure it? The red curve reaches two pixels higher and lower than the blue one. It also has a horizontal offset of at least two pixels.
what a joke of a product (pp4).
I can see it coming from a ebay chinese shipper but not from nad. very disappointing.
