unexperienced
- Joined
- Apr 16, 2021
- Messages
- 87
- Likes
- 42
Hi!
A diy project to upgrade the NAD MDC BluOS module was recently completed. The upgrade was to integrate the DSP into the sound received from the BluOS module. The project was successfully completed, and now I can safely share with you the result. The BluOS module now has an ADAU1467 DSP processor on board, running SigmaStudio. Now it is not just a module, now it is a whole complex for audio processing. There are no analog conversions inside, everything is done only in digital form. There is no need to make any changes to the design of NAD devices with slots for MDC modules. It is defined as a regular BluOS module. This has been tested with the NAD C390, NAD M12, and NAD M32. The result is impressive. Now you can adjust the sound as you like. In any desired frequency range. You can remove the resonances, remove the snorting high frequencies, add something, etc...Within a month, I found the optimal set of filters for my NAD M32 according to my preferences. The control is carried out via a USB type C port. I had to drill a hole in the rear panel of the module. A little inconvenient, but it does not interfere with the installation of the flash drive. In general, I am now very happy with the sound of the NAD M32, I tried to bypass the DSP, but always returned to the DSP again. And now I listen only with processing.
