pogo
- Joined
- Sep 4, 2020
- Messages
- 2,751
- Likes
- 1,116
These are points that should be considered under Mac OS. iOS is another matter.When plugged into the M66, it was not discovered
As far as I can judge, a Home Theater Bybass won't be a problem: Using "Presets" you can set an analog input to full volume and set presets for all other inputs to a decent volume, perhaps -40dB or so. So all you need is there. But I am not defending NAD. Working this way I destroyed accidentally my tweeters: While in "Home Theater Mode" I grabbed my iPad with the awful BlueOS app and unfortunately switched to the BluRay-Input. If my big finger would have pressed the "Preset"-button nothing would have happened but it was the source button for BluRay so I got Metallica live in Paris - not not the music as an analog signal but the raw digital signal. This was too much for my tweeters. I am really angry with myself, because I knew that this could happen.It seems that Home Theater Bypass will never come, probably it does not have the hardware to do it( relays ?).
No.Is it new hardware?
Not sure the Icon can equalize 2 subs independently. Flex might be better?The Bluesound Node Icon might be a better choice for you.
pogo said
No
".or buy a new M66 in a few months when the correction update is released."
So is it upcoming update, why buy a new one?
