I have much more faith in @pkane's assessment of Archi's technical knowledge.Archimago has probably not done itself any favors by judging new technologies without understanding how they work.
However, this topic fits better in the MQA thread.
No.
@Archimago didn't counter in the thread. Did he lack a technical understanding of the new MQA technologies?
I'm sure Archi doesn't lack technical understanding, but It sounds like you do. What problem do you think the "new" MQA really solves? And provide actual evidence, please, not links to marketing BS.
I'd guess they're extremely similar, maybe a bit less SNR because components are more packed in tight with less shielding in the M10 but probably nothing you'd notice in a room. You could also get a Bluesound Node Icon and skip the amplifier stage altogether, it still has (optional) Dirac and it's the same platform.Just a small question if i need to add more power later to my M10.
Would there be much difference between the M33 V2 and the NAD M10 V3 combined with a Eigentakt 1ET6525SA power amplifier?
And are there many downsides by adding a power amp to the NAD M10 or is it better to buy the M33?
NAD M10 V3 (2500€) + Apollon Purifi Eigentakt 1ET6525SA ST (1200€) = 3700€
NAD M33 V2 = 6500€
It is also much cheaper then buying the M33.
I would go for option a and save some money..Just a small question if i need to add more power later to my M10.
NAD M33 V2 = 6500€
That's not true.The 1ET6525SA has again been adapted specifically for the M33V2
That's not correct.There is no "specific adaptation".
Or you buy the current M33 for about €4K.Just a small question if i need to add more power later to my M10.
NAD M33 V2 = 6500€
One of us is discussing with Purifi management because he wants to understand what he is buying vs his competition.Evidence?
Is there an identical BOM including supplier?
